Author Topic: Erratic idle  (Read 14168 times)
Offline sixpot
Re: Erratic idle
« Reply #15 on: February 16, 2009, 11:22:34 am »
Update: After unplugging the air mass meter (MAF) the car ran instantly better, with a constant tickover, and no jerkiness coming off part-throttle, so it looks like this could be the problem! quoted £79.41 for a genuine replacement with my discount.
Although I might try cleaning it with carb cleaner spray first and see what happens.
Offline sixpot
Re: Erratic idle
« Reply #16 on: February 18, 2009, 05:07:32 pm »
The MAF is pretty much a sealed unit now on these cars, so I wasn't holding out much for cleaning, and sure enough it did not work!
So I've replaced it and the car is running fine now.  8)
Thanks for the offers of a VAG COM scan to everyone that offered.
Re: Erratic idle
« Reply #17 on: February 18, 2009, 07:34:54 pm »
Glad to hear a bit of good news.   :happy2:
Offline tony_danza
  • -Receive: 112
Re: Erratic idle
« Reply #18 on: February 18, 2009, 08:16:12 pm »
MAF? Bingo - as someone said they should be replaced as a matter of routine every few years, they cause no end of annoying issues and don't always throw codes to give a hint.
Glad to hear it's cool.
Sideways yo!
Offline Norbreck21a
Re: Erratic idle
« Reply #19 on: February 18, 2009, 08:36:07 pm »
Glad you got it sorted  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Erratic idle
« Reply #20 on: February 18, 2009, 08:38:13 pm »
yeah good to hear you got it sorted and reported back  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Re: Erratic idle
« Reply #21 on: February 18, 2009, 09:31:19 pm »
Checking your fuel trim with vcds could give an indication if your maf is on its way out especially if there's no cel.
http://wiki.ross-tech.com/index.php/Fuel_Trim_Info
Offline illyun
Re: Erratic idle
« Reply #22 on: February 23, 2009, 11:33:14 pm »
Interesting... mines booked in at JKM this Friday with the same problem... will let you know how it goes.  The VCDS shows lean fuel at idle ...
Re: Erratic idle
« Reply #23 on: February 24, 2009, 09:26:35 am »
You mean you are seeing a positive percentage in the first value?  My value is -0.4%
Offline illyun
Re: Erratic idle
« Reply #24 on: February 24, 2009, 12:27:31 pm »
Not sure what you mean as I'm a bit clueless but this is my readout :grin: :grin: :grin:
004506 - Fuel Pressure Sensor (G247): Malfunction
               P119A - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 44781 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:12:18
             Freeze Frame:
                    RPM: 891 /min
                    Load: 14.1 %
                    Speed: 6.0 km/h
                    Temperature: 84.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
001287 - Idle Control System RPM: Higher than Expected.
               P0507 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 44781 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:18:15
             Freeze Frame:
                    RPM: 964 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 84.0°C
                    Temperature: 13.0°C
                    Voltage: 14.351 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 44781 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:13:03
             Freeze Frame:
                    RPM: 838 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 90.0°C
                    Temperature: 31.0°C
                    Voltage: 13.970 V
Readiness: 0000 0000
Saturday,31,January,2009,03:16:51:01199
VCDS Version: Release 805.2
Data version: 20090111
Re: Erratic idle
« Reply #25 on: February 24, 2009, 02:45:02 pm »
Ah, I see where you are coming from. Hope you get it sorted.
btw VCDS version 805.3 is available for download.  :smiley:
