Author Topic: Wheel hop crazy - front left  (Read 33430 times)
Offline SteveS
« on: October 25, 2010, 06:33:38 pm »
Ok, so as the title... I get crazy amounts of wheel hop from the front left wheel.
Now, i do not believe there is any upgrades on this car in relation to engine mounts so im going to sort out a VWR lower one. Other two maybe in future..
Just wondered if anyone had any ideas really... I have the VWR LSD which i would have thought would be helping this issue but seems not to be.
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline gillm
Re: Wheel hop crazy - front left
« Reply #1 on: October 25, 2010, 06:37:46 pm »
when was the diff fitted ? i would go round and check bolts , vwr left my shocks loose and denyed all knowedge
west tuned gt28 @ 340hp
Offline SteveS
« Reply #2 on: October 25, 2010, 06:41:02 pm »
Christ, that doesn't sound good.
I believe Paulk had it fitted around march.
Wouldnt know what bolts to check?
SOLD!! :(
Offline SteveS
« Reply #3 on: October 30, 2010, 04:46:07 pm »
i have just checked and it looks like i have the vwr lower mount fitted already!
so really need ideas how how to fix this dam issue, cant put foot down at all!
SOLD!! :(
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=omi2oqagfii9g2rh813bnrafo6&/topic,19740.0.html
« Reply #4 on: October 30, 2010, 05:06:55 pm »
I check...
Front left Shock/Spring assembly
Front left drive shaft
All wishbone bushes
Offline SteveS
« Reply #5 on: October 30, 2010, 05:09:08 pm »
lol, If i knew where to start. i had a look today and saw nothing but i dont really know what to look for..
only thing i noticed today when i looked today was the tire pressure was 2.6 on FL, other 3 were like 2.4.
SOLD!! :(
« Reply #6 on: October 30, 2010, 05:10:18 pm »
Tyres should be 2.6 all round according to the handbook!
Offline gazbutS3
« Reply #7 on: October 30, 2010, 05:11:19 pm »
I changed the side mounts yesterday, and the gearbox side mount was very sloppy, I wonder if this would cause your condition????
Offline SteveS
« Reply #8 on: October 30, 2010, 05:12:35 pm »
you changed the side mounts and it made things worse??
SOLD!! :(
Saint Steve
« Reply #9 on: October 30, 2010, 05:45:17 pm »
Put the car back to stock steve, see if it still bounces. At least that will tell you if its too much power or a mechanical /suspention etc/ issue with your car.
Offline gazbutS3
« Reply #10 on: October 30, 2010, 06:23:18 pm »
no not at all, didn't have an issue, but I wondered if the amount of play in the gearbox mount could cause something like this????
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: October 30, 2010, 06:34:53 pm »
I would suspect the console bushes if they are still the original.
Stu...
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #12 on: October 30, 2010, 08:55:59 pm »
usually a good sign somethings loose. either bushings or fixings
can you move engine by hand back and forth?
subframebolts could be loose
balljoints etc
how much does the engine move when taking up drive against the handbrake ? (try it with bonnet up)
if you can prove nothings loose , and its the side mounts then get them changed. even going to OE would help , but id advice going to THS or even to VWR as a better long term option
Im assuming the shocks arent past their best (ie no oil?)
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveS
« Reply #13 on: October 30, 2010, 09:13:40 pm »
if i knew where the subframe and balljoints were i would look :p
how do i check suspension oil??
i have tried contacting matt at VWR but he never replys to the emails i have sent, during the week its very difficult to get time to call. rather annoying.
SOLD!! :(
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #14 on: October 30, 2010, 10:12:53 pm »
you dont check shock absorber oil per se, more look for leaks and confirm it rebounds correctly on that side. (push on strut tower on that side , it should be firm)
shocks (as well as mounts/tyres etc) are all interlinked in terms of getting wheel hop dynamics.
the other thing to look for are 'shiney seating areas' where theres a loose bolt and the item moves around.
i all honesty, youre stuck getting VWR or another competent garage to look at it  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
