August 21, 2024, 02:43:42 pm
All Things Mk5
Technical Workshop
Replacing front wishbones
Topic: Replacing front wishbones (Read 1412 times)
xxx_mojo_xxx
Just look at my post count
-Given: 39
-Receive: 19
MUBster DUBster
October 25, 2010, 08:52:19 pm »
If I was to replace the front wishbones with a set from a S3 is there anything I would need to change? For instance, press new bushes, longer bolts, etc.
Also would I need to get the car tracking redone?
P.S. I already have a WALK fitted.
TIA.
Mo
Teutonic_Tamer
-Given: 88
-Receive: 95
GreasedMonkey - HoofHearted - GTI now mod'ed!
Re: Replacing front wishbones
Reply #1 on:
October 25, 2010, 10:01:54 pm »
I think they are plug and play (in respect of not needing any additional bits) - but you would ideally need alignment done - because you need to remove the WALK.
xxx_mojo_xxx
-Given: 39
-Receive: 19
MUBster DUBster
Reply #2 on:
October 25, 2010, 10:51:18 pm »
Cheers T_T. Should I take the opportunity to replace the yellow rubber/plastic bushes in the WALK?
Teutonic_Tamer
-Given: 88
-Receive: 95
Reply #3 on:
October 25, 2010, 11:13:53 pm »
Quote from: xxx_mojo_xxx on October 25, 2010, 10:51:18 pm
Only if they have visible signs of wear, or are split. Otherwise just re-grease them.
xxx_mojo_xxx
-Given: 39
-Receive: 19
MUBster DUBster
Reply #4 on:
October 26, 2010, 10:00:43 pm »
Ok, will do.
All Things Mk5
Technical Workshop
