Author Topic: Forge catch can (PCV fix)  (Read 1344 times)
Offline HALL1E123
« on: October 27, 2010, 07:45:48 pm »
Hi Guys,
Just been looking at the forge catch can system, Both lines from the catch tank join to the rocker cover which is esentially making this a closed system, can anyone tell me how the pressure is releaved without it venting to atmosphere and with also losing the return to the inlet manifold? Bit confused as to were it goes obviously you constantly have blow by even more so as revs increase so does this not just pressurise the crank case/rocker cover?
Sorry if im just having a moment   :signLOL:
Regards,
James.
