Author Topic: Fitted the THS side mounts  (Read 11365 times)
h4rdy
Re: Fitted the THS side mounts
« Reply #15 on: October 30, 2010, 04:16:57 am »
all the casings and fitments had VAG numbers on, they are fitted so can't see them, maybe John could take some pictures before he fits his :happy2:
Ill have a look at mine as not fitted yet but the boxes had VAG numbers on?
I know that means nothing but just thought I would mention it.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #16 on: October 30, 2010, 08:49:40 pm »
the drivers side mount has this on the top (engine side)
passengers side has no markings
Id be surprised if they were THS own castings (and less happy tbh). def look like refurbed OE mounts to me
Red ED35 5dr DSG
BLOG | BUILD
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #17 on: October 31, 2010, 06:20:47 pm »
fitted mine this morning  :happy2:
took me couple of hours taking my time. biggest hassle is getting all bits out of the way to get to the bolts.
drivers side most things can be left connected (dont try and start the car with the reservoir tube disconnected  :signLOL:)
you really need 2 jacks or axle stands, as others have pointed out you will be amazed how 'loose' the engine is with a mount removed!
so you definitely need an extra jack to hold the engine while swapping mounts.
I also found it easier to bolt the body side first then the engine side of each mount, be careful not to cross thread the bolts.
I reused my bolts, kept them in order. (punch holes in the THS box to keep the orientation  :happy2:)
the defined torque specs def need a torque wrench as + 1/4 turn is a lot of force (try and do a smooth movement if you can)
my old mounts were nothing short of chocolate fireguard material. easily moveable by hand (both of them) in all directions  :surprised:
no fluid present. At some point I will cut them open for a look they are beyond worn. (my car is at 44k miles)
new mounts fitted just fine. Like gaz mine are louder than I expected while accelerating, not unpleasant but kind of intake like (although Im OE intake) , and as Robins says lots of grrrr. they should soften
funny though, they are fine at idle, noticeable on the startup, quiet on light/no throttle. the noise on part / full throttle is hard to describe! sounds like my big/little ends have gone ! combined with some gearbox whine and intake type noise.
no engine movement and the positive drive experience is brill. the feel on clutch takeup is much better , the downside is that the horrendous clutch 'feel' on takeup of drive just sounds worse.
will see how they soften in weeks to come. so far a great mod thats not for the paranoid  :signLOL: with all these new engine sounds
(oh and how fking heavy is that battery  :signLOL: , always thought REVO went to 'stock' after battery disconnection but mine seems to still be in performance mode ???)
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #18 on: October 31, 2010, 06:48:41 pm »
They sure do make some strange but good noises  :laugh:  :laugh:
Mine have been on a week / 550 miles and have soften a bit but not much. The cabin noise and vibration has remained the same  :happy2:
« Reply #19 on: October 31, 2010, 07:12:38 pm »
Feel the good vibes, man  :evilgrin:
The soundz aren't everyone's cuppa tea but I expect that the big improvement in the drivetrain is to most folks' liking  :happy2:
Offline gillm
« Reply #20 on: October 31, 2010, 07:14:00 pm »
my bsh ones calmed down after a few thousand miles and a good hammering round the ring
west tuned gt28 @ 340hp
Offline Cupra R
  • -Given: 18
« Reply #21 on: October 31, 2010, 07:40:34 pm »
Still to get round to fitting mine  :ashamed:
Ordered some tool's to do them with though  :happy2:
Offline gazbutS3
« Reply #22 on: October 31, 2010, 07:44:51 pm »
gonna break mine in at Anglesey on the 20th Nov :happy2:
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #23 on: October 31, 2010, 08:26:22 pm »
Wonder why they blitzed the VAG markings in their web fotos then? :sad1:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #24 on: October 31, 2010, 08:46:06 pm »
dont think they have, only the drivers side has numbers, the gearbox doesnt (dont know why not!)
Red ED35 5dr DSG
BLOG | BUILD
  • -Given: 88
  • -Receive: 95
« Reply #25 on: October 31, 2010, 08:50:09 pm »
Yup - now you know why the flexi section on the down pipe is limper that Justin and Ryans wrists! :evilgrin:
It is MUCH easier if you use anti-seize on the bolt threads.  It wont affect the torque settings, because the primary torque figure is quite low - the tensile setting is from the angle turn.
Seems common.  Mine were well sloppy after about 20k - the inside of the metal housing had been 'polished' to a shine.
The fluid is only on the cambelt side mount - turn it upside down, and it is under a black rubber diaphragm with a rectangular blue nylon-esque retainer.
We really need to compare these THS mounts with my silcone filled new OEMs.
You wanna lift a heavy batt - look at this monster - the standard GTI is a 72Ah (278x175x190mm and 20kg), whereas the beast in the RS4 is a 110Ah (393x175x190mm and 29kg):
  • -Given: 88
  • -Receive: 95
« Reply #26 on: October 31, 2010, 08:51:14 pm »
Does your gearbox whine in 2nd?  (Oh, are you manual or DSG?)
