Author Topic: Help epc light on and no power  (Read 25295 times)
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
Re: Help epc light on and no power
« Reply #15 on: October 30, 2010, 09:15:58 am »
With your broken oil cap sagas, me thinks it is something to do with incorrect pressures in the crankcase ventilation - which will lead to errors in the air/fuel mixture. :wink:
But as others have said, get it scanned with VCDS asap - and then post your fault codes.
what would cause this problem and would it be an expensive fix
Your crankcase ventilation system is linked into your inlet manifold - any leaks anywhere in the intake system will really mess up the air/fuel mixture, therefore messing up the overall running of the engine, and ultimately throwing a warning light on the dash and will make the engine go into 'limp home mode' (where the engine feels utterly gutless, and wont rev over 3,000 rpm).
Offline stu_no_1
« Reply #16 on: October 30, 2010, 09:25:02 am »
i have bluefin stage 1 on it should i go back to stock till i find out or wait till i get it scanned incase it clears the fault codes
Nasir
« Reply #17 on: October 30, 2010, 10:23:24 am »
Cant the bluefin handset get the codes from your car? I'm sure I read it somewhere.
Offline stu_no_1
« Reply #18 on: October 30, 2010, 11:53:26 am »
im not sure if it can ive heard something about it but never really looked into it
Offline stu_no_1
« Reply #19 on: October 30, 2010, 12:21:43 pm »
just restored the original map back on still getting the light coming on and the car is idling really rough feels like its misfiring also the bluefin had no option on it to scan for codes just imobilise or blufin
Offline stu_no_1
« Reply #20 on: October 30, 2010, 07:41:31 pm »
got aa out the guy had vagcom told me it was the fuel pump thats the problem
  • -Given: 88
  • -Receive: 95
« Reply #21 on: October 31, 2010, 04:41:14 pm »
Which fuel pump?  The car has two very different pumps!
Me thinks if the AA diagnosed it with VCDS (aka VAG-COM) - then it is probably the in-tank low pressure fuel pump.
Offline stu_no_1
« Reply #22 on: October 31, 2010, 06:32:55 pm »
im not sure what fuel pump but it definatly was vagcom he had im going to try get it scanned again and get the actual fault code that came up im sure it was something about fuel pressure regulating but i honestly cant remember for sure
Offline PDT
  • -Receive: 142
« Reply #23 on: October 31, 2010, 06:36:16 pm »
Dont blame the mechanical HPFP immediately, i have seen this fault caused by various other components. I would reccomend finding a local specialist that can help, or a member on here that has vcds that can take some logs and post up any fault codes.
Offline stu_no_1
« Reply #24 on: October 31, 2010, 06:40:09 pm »
i was speaking to a guy who works for vw and he said it might be the fuel pressure regulator but he said get vcds done and then he can tell me whats wrong
im gettin my mate to scan it tomorrow night all going well he has a mk4 gti so i dont know if his lead will do my car might need a newer one for can ive heard is this right or will his lead be able to tell me fault codes
  • -Given: 88
  • -Receive: 95
« Reply #25 on: October 31, 2010, 09:28:22 pm »
If it mentioned fuel pressure - then I'd stick my neck out and say it is NOT the pump.  More likely to be the fuel pressure regulator, of which there was a recall-type service action.
Offline gillm
« Reply #26 on: October 31, 2010, 09:49:35 pm »
i had that sensor go but had no issues like above all i had was a massive flat spot from 4k up , i would be a little more concerned about splitting 3 oil caps , something is pressurizing (head gasket , worn rings ?)
west tuned gt28 @ 340hp
Offline stu_no_1
« Reply #27 on: November 01, 2010, 04:26:20 pm »
fault code p2294 fuel pressure sensor open circuit or bad connection
any help i got this from my local garage they ran their diagnostic machine on it not vag com i cant get any1 to scan it with vag com
and i think the oil cap thing is due to my engine cover being held on my one mount as whoever serviced it last snapped the others off so there is a bit of movement in the cover possibly knocking against the oil cap
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #28 on: November 01, 2010, 04:40:02 pm »
Stu...
Offline stu_no_1
« Reply #29 on: November 01, 2010, 04:46:48 pm »
the garage told me it was p2294
