Author Topic: Door Warning Lights Mod / Retrofit  (Read 27242 times)
Offline mortygttdi
  • -Receive: 146
Re: Door Warning Lights Mod / Retrofit
« Reply #30 on: August 21, 2011, 11:14:44 pm »
Theres a ground on the electric window button brown/white wire.
Darren
MPS
« Reply #31 on: August 22, 2011, 08:41:34 am »
Thanks for the reply! I ended up taking ground from the brown wire on pin 2 on the 32 pin plug.  :pomppomp: :pomppomp:
procrastinator
« Reply #32 on: September 29, 2011, 09:30:28 pm »
I've a Golf Plus 1.9TDi 2005. I managed to fit the fronts fine. However, the rear doors are proving a pain. I see above, you managed to connect up to the lock plug for the +tive? I can take a 12v positive from the controller plug but the light stays on when I close the door even after setting up through the Vag-com.  Is there a spare pin on the lock? someone mentioned pin 4!
Offline VW_rabbiter
« Reply #33 on: July 01, 2013, 09:07:35 am »
Hi,
sorry to bring this topic back to live.
hoping anyone having the same problem as me can give us some insights......
Rear door card puddle lights not working, and what i have done so far:-
1. coding in 42, 62 & 72 already changed;
2. Pin 14 is taken, so tried Pin 6 as 12v, still no use (Pin 4 as ground already plugged in);
3. used voltage-meter to test the pins inside the controller, the meter didnot get a reading at all on all pins;
4. Lights & wires tested by touching direct to the battery and confirmed working;
car is Mk5 2006 1.6FSi (I am convinced the car was manufactured before June 06, so it uses the old controller module)
front puddle lights work and shine like Christmas Tree.....
Can anyone help me how to solve the rear lights connection problem?
many thanks.
a VW'er from Hong Kong
Offline VW_rabbiter
« Reply #34 on: July 02, 2013, 02:23:35 pm »
today tried pin 6 as positive and pin 4 as ground, and no lights!
any one can help me?  :confused: :confused:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #35 on: July 02, 2013, 02:33:40 pm »
have you tried pin 1 for 12v? thats where mines put in
« Last Edit: July 02, 2013, 02:35:17 pm by vw55raz »
Offline VW_rabbiter
« Reply #36 on: July 03, 2013, 06:38:05 am »
Hi vw55raz,
pin1 as 12v for rear door puddle lights? (and pin 4 as ground remains)
thanks
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #37 on: July 03, 2013, 07:06:36 am »
they won't work on the rear doors
when I did them on my old car, i wired them into pin 4 on the actual door lock (this would be a switched earth) take the power from the main Red & yellow wire. no need for coding
Cluster and Key coding
Location Great Yarmouth
Offline VW_rabbiter
« Reply #38 on: July 03, 2013, 11:47:48 am »
Hi Eddie,
so wot you r saying is .... even though I activated the coding for the rear doors, none of the pins at the controller will enable the puddle lights to be swtiched on?
.........  :rolleye: :rolleye:
Offline marko
Offline VW_rabbiter
« Reply #40 on: July 03, 2013, 12:51:51 pm »
Hi vw55raz,
thanks
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #41 on: July 03, 2013, 02:42:48 pm »
Hi vw55raz,
thanks
Oh sorry, pin 1 is for fronts,
have you referred to the web link that MARKO has posted up?
Double check the coding in vcds.
By the way they are called door warning lights, puddle lights are the ones which go on the wing mirror.
Offline marko
« Reply #42 on: July 03, 2013, 02:44:31 pm »
my golf is 2007 and i used the link i gave above and mine work fine...
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #43 on: July 04, 2013, 06:11:12 pm »
they would as they are GEN3
GEN1 & GEN2 won't work
hence why you have to hard wire them
