Author Topic: My Auto Lights coming on in bright sunshine  (Read 3294 times)
Offline CAPTAIN BRITAIN
« on: October 30, 2010, 03:31:38 pm »
Has anyone had problems with the Auto lights feature on their GTI?
Mine come on randomly in bright conditions and don't go of untill i swith it off manually.
Where is the sensor for the Auto lights?
Re: My Auto Lights coming on in bright sunshine
« Reply #1 on: October 30, 2010, 03:43:39 pm »
This is a deliberate feature. Think it was discussed about a year ago.
clicky
from what i remember reading the auto lights should have the functions
- auto on when unlocking in low light
- follow you home when locking the car in low light
- auto on for a period of time spend over 90mph but will switch off when
you stay under 10mph (not sure but i think its 10mph) for 5 minutes
- auto on in dazzle conditions, ie bright sunlight
- auto on in low light
this is with the switch into the auto postition btw
they should also auto level from ignition with a minimum of 2 movements
edit: is your windshield clean? the sensor lives on the reverse of your rear view mirror facing out behind the glass, as you look into your car from the front its the dark square patch in the middle at the top
« Reply #2 on: October 30, 2010, 05:43:37 pm »
I bought the car this summer, and the lights never came on in bright sunlight,
My windscreen is dirty, gonna clean it tomorror, i hope thats the thing causing it
By the way this happened the very same day i had the car re-mapped, Could the new software affect the Auto lights by any cahnce?
Or just coincidence?
Offline Russ_leeds
« Reply #3 on: October 30, 2010, 05:44:19 pm »
also i find that with the bright sunshine comes shade off the buildings and this makes mine come on
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline boxxer1973
« Reply #4 on: October 30, 2010, 07:21:28 pm »
Is there anyway of changing the sensitivity with vcds?
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
Offline dmac1969
  • -Receive: 21
« Reply #5 on: October 30, 2010, 07:26:22 pm »
Would it not be easier just to move the switch to 'Off' and put the lights on yourself when you need them? I never use auto lights.
Offline keith
« Reply #6 on: October 30, 2010, 08:23:41 pm »
Is there not something whereby the car reaches a certain speed the lights are activated? or am i thinking of another car?
« Reply #7 on: October 30, 2010, 08:31:45 pm »
If you read reply #1 keith, where I quote Mr Cherry, you'll see that I've already mentioned they come on above 90mph or so.
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #8 on: October 31, 2010, 10:30:10 am »
They come on in the winter a lot more becuase the sun is lower in the sky.  IIRC the system compares the light from the light sensor on the windscreen and from the rear (via the auto dip mirror sensor) and compares the two, it uses this to determine if its a 'dazzle' condition.
Sepang Blue S4 BE Avant
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #9 on: October 31, 2010, 05:10:30 pm »
Yes, but not exactly as the quoted text from Very Cherry.  The Auto lights will activate dipped headlamps when the speed rises above 120 km/h (about 80mph) for more than 2 minutes, and then will go off when the speed goes below 100 km/h (62 mph) for more than 5 minutes.
The settings can be adjusted in VCDS - but is rather tricky and confusing to explain.
THE biggest cause of incorrect auto lights (and auto wipers) is the fitment of non-OEM windscreens.  If you've ever had AutoGlass, or any of the other screen companies supplied by AutoGlass - then you are highly likely to have a very poor quality screen - optically not pure, and with no consistency of tint.  The variances of tint in non genuine screens give the wrong 'readings' to the light/rain sensor.  This is not unique to VWs - it is an industry wide issue which affects all automakers.
« Reply #10 on: October 31, 2010, 05:44:05 pm »
....Exactly! I very rarely use auto lights as my LED DRL's always ensure I can be seen by other motorists (if they're awake). And if they ain't awake I blast 'em with my Italian airhorns!  :wink:
