Author Topic: Changing the BCM  (Read 12322 times)
Offline uk_stu
Changing the BCM
« on: October 31, 2010, 08:39:39 am »
Hi guys,
I'm looking into retrofitting fog lights into my car.
I've found the kufatec wiring and will have to get a light switch/fogs/grilles
But the Kufatec wiring requires a highline BCM (body control module)
Does anybody know how expensive this will be if i were to get one from vw/breakers...
And would i need to re-code the car once it has been replaced or would i be opening a whole bag of worms?!!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Changing the BCM
« Reply #1 on: November 07, 2010, 11:04:38 am »
Hi
This depends on which MY your car is
BCM refers to the newer types of controller which manages the electrical and comfort options in the car from around 2009
before the 2009 there were 2 controllers CECM and CCM.
The best thing you can do is find out what you have fitted now and work from there. have your car scanned with VAG-com and that will tell you what you have
Cluster and Key coding
Location Great Yarmouth
Offline apollo13
  • -Receive: 47
« Reply #2 on: November 07, 2010, 11:11:15 am »
Sorry for jumping in but seeing as your on here Ed do you know anyone with a 30 byte cecm?
I havnt looked on ebayde yet but thought you might have one lying around  :grin:
Cheers mate.
Offline uk_stu
« Reply #3 on: November 07, 2010, 11:12:58 am »
I have a non highline CECM, and got myself a highline cecm from non other than Darren (morty)
Offline apollo13
  • -Receive: 47
« Reply #4 on: November 07, 2010, 11:14:48 am »
Cheers Stu,
But I have a highline already but Im after the 30 byte version.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: November 07, 2010, 11:32:54 am »
Yes Ebay.de is your best bet. I had one for sale afew months back only got £60 :sad:
Offline apollo13
  • -Receive: 47
« Reply #6 on: November 07, 2010, 07:24:46 pm »
Id of given you £65!  :grin:
Ill be on the lookout, if you see or hear of one let me know mate.  :drinking:
Ed there are a few on ebay.de, apart from the cornering fogs have you found anything else worth enabling?
« Last Edit: November 07, 2010, 07:48:20 pm by apollo13 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: November 07, 2010, 08:40:11 pm »
Hazzard flash under heavy braking
if you don't have the car set to autolock, then the tailgate only can be enabled to lock at 15mph
Offline apollo13
  • -Receive: 47
« Reply #8 on: November 07, 2010, 08:47:19 pm »
Oh yeah I knew about the hazzards under braking.
Not that much then, I think Ill save the £120-130 quid and put it towards an RNS!
I would of had one for £60 though!
Cheers Ed.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Offline apollo13
  • -Receive: 47
« Reply #10 on: November 07, 2010, 09:00:51 pm »
Cheers for the links Ed,
Their the ones on ebayde I saw, they work out about £120 £130 not worth that for cornering fogs IMO!
Im not too bothered about having one but if I see one for a bargain Ill get it!
Handy link to the recycling place though, I usually use retek but even their a bit steep sometimes.
What happened to the dirty breakers yards where you could strip the parts yourself and grab a bargain??
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: November 07, 2010, 09:08:57 pm »
The cornering ligh feature is nice, but your right that you should put that money towards an RNS510 with voice control
