Author Topic: repair wires and connector part numbers  (Read 21344 times)
Offline apollo13
  • -Receive: 47
« on: November 01, 2010, 05:45:45 pm »
Hi Guys,
I need to make to harnesses for a mod Im doing on the rear taillights.
What I need to acheive is a bridging section between the rear light cluster loom and the light itself, on both sides.
So Im after the part numbers for 2 male connectors, 2 female connectors, 8 male repair wires and 8 female repair wires.
This is just to avoid splicing into the factory loom.
Hope this makes sense?  :rolleye:
Lee.
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: repair wires and connector part numbers
« Reply #1 on: November 01, 2010, 06:52:00 pm »
Here you go Lee -
1mm CSA wire 000 979 134 Male connections.
1mm CSA wire 000 979 133 Female connections.
2.5mm CSA wire 000 979 226 Male connections.
2.5mm CSA wire 000 979 225 Female connections.
191 972 701 Housing
191 972 711 Connector Housing
Stu...
Offline apollo13
  • -Receive: 47
« Reply #2 on: November 01, 2010, 07:00:05 pm »
Cheers Stu,
Your an  :innocent:
Offline SeanyK
  • -Given: 35
« Reply #3 on: November 01, 2010, 11:25:14 pm »
Hi guys!
Don't suppose you know which one I need for a wire for the Central Electrics module? Just a run of the mill 'push' in pin type connector I believe to go into one of the main plugs on the CEM? It was on a thin wire if that helps?!
Same type that go into the quad-lock connectors at the back of the radio.
I've got a list of part numbers;
000 979 131 A,
000 979 020
etc etc
Or would one of the above posted by Stu work for this purpose?
It's this type;
« Last Edit: November 01, 2010, 11:52:18 pm by SeanyK »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: November 02, 2010, 06:58:51 am »
Sean look on the plug and there will be a part number, give me the number and I'll get you the number for the wire.
Stu...
Offline SeanyK
  • -Given: 35
« Reply #5 on: November 02, 2010, 12:14:10 pm »
I think I may have hit the jackpot... The guy who fitted my parking sensors this morning had a VW quadlock connector in his boot, and just took 2 wires with the connectors on off and gave them to me!
Hopefully, fingers crossed!
If not, i'll get back to you asap with plug number mate,
Thanks,
Sean
Offline SeanyK
  • -Given: 35
« Reply #6 on: November 02, 2010, 09:19:57 pm »
OK the dream is over... It wasn't the right pin! So if possible could you tell me which repair wire I need mate;
I had a look under and saw the following part numbers;
For the CEM = 1K0 937 049 N
I pulled out one of the same brown plugs (not the one I did yesterday though as it's a bitch to get back on, so saving that for only when I HAVE to undo it lol)
Brown plug part number = 1K0 972 929 (A?) That A may not be relevant it was just in a circle at the end of the plug!
So any wire repair that fits the above plug would do? And if you can let me know the part number, is it something my local-to-work Audi dealer can get hold of?
Many thanks,
Sean
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: November 02, 2010, 11:33:06 pm »
Sean
There are lots of numbers for that plug, does it have different sized wires in??
000 979 025 E
000 979 026 E
000 979 150 E
000 979 151 E
000 979 242 E
000 979 243 E
000 979 255 E
000 979 308 E
Stu...
Offline SeanyK
  • -Given: 35
« Reply #8 on: November 02, 2010, 11:44:06 pm »
Hi Stu, yeah I think it has a few wires in it of different sizes.
Are those wires expensive? Was thinking i'd just buy all of them and hope one of them is right?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: November 02, 2010, 11:46:43 pm »
About a £1 each.
If you have a friendly dealer then they will likely carry most of them in the VAS toolkit for repairing cables so they may have a look for you if you take your old wire in.
Stu...
Offline SeanyK
  • -Given: 35
« Reply #10 on: November 02, 2010, 11:53:16 pm »
About a £1 each.
That sounds a plan, i'll try the Audi dealer as it's literally 2 mins walk from work, but in the past they haven't been particularly helpful, almost a 'it's not an Audi, so no' type attitude.
Thanks though mate, if all fails, i'll just get all those wires! :grin:
Offline apollo13
  • -Receive: 47
« Reply #11 on: November 03, 2010, 10:50:23 am »
Probably a bit late now Shaun but that wire is 1mm so as long as your replacement is the same size or bigger it wont matter. To be honest I think 1mm is the smallest anyway on that connector.
Offline SeanyK
  • -Given: 35
« Reply #12 on: November 03, 2010, 01:34:52 pm »
Well, the Audi garage were most helpful...Not, claiming they had a box of wires and would take ages to go through it, brought a few out, one looked very similar just a bit smaller connector, after thinking I said "can I have that other one back I'll buy it" to which I got a reply "I don't know where it is now, its back in the box..."
Nice.
VW Were more helpful, going through ETKA on screen with me but told me they were all quantities of 5, so i'd have to buy 5 just to see!
Off to a specialist VW garage in a min to check there!
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #13 on: November 03, 2010, 09:33:38 pm »
They are sold as Qty 5 but i've never found a dealer that sticks to that.
Stu...
Offline apollo13
  • -Receive: 47
« Reply #14 on: November 06, 2010, 03:07:10 pm »
Stu I have just picked up the bundle of repair wires and connectors and the ones you suggested are not the ones Im after.
They are only a one pin connector and socket. I was after the four pin plug and socket that is on the end of the loom that goes to the outer rear light cluster.
Thanks mate
