Author Topic: Vredestein Ultrac Sessantas  (Read 5127 times)
Offline winrya
Re: Vredestein Ultrac Sessantas
« Reply #15 on: November 15, 2010, 04:50:59 pm »
Please keep us posted, I'm tempted to try although they feel prefect at 2.6 bar. Be interested to know what evo ran them at when the came second in their tyre test?
Offline TagnuT
« Reply #16 on: November 15, 2010, 07:24:07 pm »
Found this elsewhere:-
http://rb320oc.ipbhost.com/index.php?showtopic=2920
I emailed Vredestein Uk yesterday to ask their opinion, seeing has how every forum has a different opinion and this is their reply
Thank you very much for your Email as we appreciate all feed back from our customers.
For the correct tyre pressure, please refer to the pressure indicated in the instruction manual of the car or on the door frame or inside the tank lid, please take in to account the Normal Load pressures and Heavy Load pressure.(Extra load, XL, Tyres + 4 psi)
The tyre pressure Vredestein advises is calculated on maximum load.(See Website) It is normal for a tyre to lose a bit pressure after a while. Our experience is that people do not regularly check their tyre pressure. Vredestein advices this higher pressure because we want to avoid too low pressure which can irreparable damage the tyres, is responsible for more tyre wear, moreover it causes unnecessary fuel consumption.
With a bit extra pressure all these negative aspects will be avoided, the only thing is that the vehicle may feel less comfortable but in practice this comes out marginal.
We hope this answers your question.
If you would like me to contact you, please send me a contact number and i will get back to you ASAP.
Yours Faithfully
Mark Kearns
Vredestein (UK) Ltd
And this one:-
http://www.detailingworld.co.uk/forum/showthread.php?t=156514&page=3
1. TYRE PRESSURE
The tyre pressure must always correspond with the pressure recommended by the car manufacturer.
Bye Bye Edition 30.
Offline Boothy
« Reply #17 on: November 15, 2010, 07:31:38 pm »
Straight from the horses mouth then. Glad this got cleared up too as I've recently fitted a pair.
Offline seiko
« Reply #18 on: November 15, 2010, 08:43:41 pm »
when I collect my car from York 5 weeks ago, took it to the local gorge to replace rear tyre as it was badly worn on the inside, drove off after having new tyre fitted and a mile down the road the tyre pressure light came on, pulled in to service station and checked pressure and had 49psi in it, put the pressure down to 36 psi and reset the button in the car and all fine again, just think 49psi is to high?
Offline TagnuT
« Reply #19 on: November 15, 2010, 09:30:06 pm »
My tyres are all at 36psi at the minute and I am quite happy with the ride and handling at the moment. Must say that the Vreds are less tippy toe this morning at these lower temps than the GY Eagle Asymmetrics were. :happy2:
Bye Bye Edition 30.
Offline budge28
« Reply #20 on: November 15, 2010, 10:28:28 pm »
Yours Faithfully
Mark Kearns
[/i]
Vredestein (UK) Ltd
And this one:-
1. TYRE PRESSURE
Never heard of this before from a manufacturer, putting more air in the tyre cause over time they go down!  They loose there pressure cause the moisture in the compressed air seeps through the rubber, so if you put nitrogen in your tyres this wont happen.
In this case what are the correct pressures? how much is there bit of pressure over? and how long is their "after a while" that the tyres are overinflated?
Offline budge28
« Reply #21 on: November 15, 2010, 10:34:24 pm »
Just noticed Vredestein advised pressure is calculated on maximum load, who drives with that all the time anyway. Im normally half that.
Think ill just stick to car manufacturers spec as said on the other website.
Offline winrya
« Reply #22 on: November 15, 2010, 10:55:10 pm »
I've found them to be superb in the wet, ice and snow.  I'll keep putting them on my cars because of this reason
« Reply #23 on: November 16, 2010, 02:39:14 am »
putting 44psi in a tyre with a car that is unladen will be a bit bouncy and also will wear the middle of the tyre out quicker
Offline gti265
« Reply #24 on: November 16, 2010, 11:54:21 am »
hmmm i might be lowering the pressure in mine this morning then, back to 2.6bar, although they do seem fine with the higher pressure and normal driving
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline lozzriot
« Reply #25 on: November 16, 2010, 12:39:13 pm »
Having ran mine for a week at the high pressures I've now gone to the stock pressure and I think the car feels a lot more stable at the lower pressures, I may try the stock pressure + 4psi and see how I that goes...
