Author Topic: Mk6 instrument cluster in a Mk5  (Read 30469 times)
Offline matski
« on: November 07, 2010, 10:48:33 pm »
Will a Mk6 instrument cluster fit in a Mk5? I know the Mk6 steering wheel fits.
Oly
Mk5 GTI DSG, Steel Grey, 2006, 25,000miles, RNS-510, LED DRL's (Ultra Auto), Fiscon Bluetooth, Luxury Pack, Rear Parking Sensors, 18" Monza II Shadows, Milltek Non-Res. Exhaust, Painted Rear Bumper, Revo Stage 1, TPM.
Offline G60s GO
  • Edition 30, Plaque No.0100
Re: Mk6 instrument cluster in a Mk5
« Reply #1 on: November 07, 2010, 11:04:08 pm »
I'm pretty sure it won't fit as the dash recess and cluster is a completely different shape? I think the Mk6 uses a different type of computer system which probably won't be compatible with the Mk5's system.
Someone on here is bound to know for sure though mate :happy2:
  Perfection Is Perfectly Simple; Fouling Things Up Requires true skill.
« Reply #2 on: November 07, 2010, 11:04:28 pm »
i asked the same question here is the LINK
Welcome to the forum
Offline matski
« Reply #3 on: November 07, 2010, 11:23:02 pm »
Cheers, so if I retrofitted a Scirocco cluster it would work? Could I fit the entire cluster including the new white-on-black highline?
« Reply #4 on: November 07, 2010, 11:31:59 pm »
i was advised it might be possible but thier is to many things to change over and the later vw run on a different soft ware
Offline matski
« Reply #5 on: November 07, 2010, 11:34:36 pm »
What does it involve?
« Reply #6 on: November 07, 2010, 11:42:28 pm »
mm not sure to be honest..best sending Eddie-nL or Darren (mortygttdi) a pm who will advise you better  :happy2:
Offline matski
« Reply #7 on: November 07, 2010, 11:44:01 pm »
Ok, I will do tomorrow, thanks
Offline Garth
    • My Build thread
« Reply #8 on: November 08, 2010, 06:23:52 pm »
It will fit, you just need the right bits to make sure they work  :happy2:
2010 Jetta in South America has mk5 interior, mk6 bits:
Offline apollo13
  • -Receive: 47
« Reply #9 on: November 08, 2010, 06:27:16 pm »
Beat me to it Garth!!
It will fit but wont work without major electronic surgery   :rolleye:
Offline Garth
    • My Build thread
« Reply #10 on: November 08, 2010, 06:28:31 pm »
All you need is the right controllers. It's a relatively easy swap.... but not cheap  :grin:
Offline apollo13
  • -Receive: 47
« Reply #11 on: November 08, 2010, 06:34:15 pm »
Garth do you know when the new black display came out? If its after 2007 youd have a nightmare recoding the cluster due to not being able to get the skc?? Even if you got hold of all the controllers?
Offline Garth
    • My Build thread
« Reply #12 on: November 10, 2010, 09:55:13 am »
It was after 2007 and you are correct, coding the clusters would be too difficult for most of us. There are companies out there who will do it (Star performance being one of them). As I said before, it would not be cheap as you'd have to replace most of the electronic controllers in the car to get everything talking together. You'd probably end up with more mk6 than mk5 components  :grin:
Offline apollo13
  • -Receive: 47
« Reply #13 on: November 10, 2010, 11:00:22 am »
Like I said mate major electronic surgery!   :grin:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: November 10, 2010, 08:32:15 pm »
If you bought a new cluster it would come with the log in, read your current pin and code with vcds
Cluster and Key coding
Location Great Yarmouth
