Author Topic: Intermittent Problem - "STOP - CHECK COOLANT"  (Read 8171 times)
Offline Norbreck21a
« on: November 08, 2010, 07:50:57 am »
Guys,
I got the above warning a few times during the bad winter we had in Jan / Feb this year, and it came on again once last week, and again this morning.
The DIS display bonged and displayed - "STOP ! CHECK COOLANT".
I did the same thing as I did last time, i.e. actually check the coolant which as suspected was right between the MAX and MIN line (where it always is), so I don't think I've lost any coolant ? After turning the car off, and re-starting, the warning disappeared ?
My guess is that it's a bad sensor but which one ? The only other thing is when it happened last week, the outside temp was approx 2°C and the car covered in frost. This morning the ice warning was on again and the temperature was 3.5°C, so it would seem that it's only affected in cold weather ?
Anyone any ideas ?
Andrew
Re: Intermittent Problem - "STOP - CHECK COOLANT"
« Reply #1 on: November 08, 2010, 09:04:07 am »
thier is a sensor inside the the coolant bottle..orobs that one that is faulty
Offline Norbreck21a
« Reply #2 on: November 08, 2010, 10:25:11 am »
Ah cheers Maxitrol.
Any idea if these are cheap and easy to replace ?
Offline richtung
  • -Receive: 56
« Reply #3 on: November 08, 2010, 10:54:53 am »
Its a well know problem on the MK4 - not sure on the MK5.
You have to replace the whole bottle which is less than a tenner from VW (im not sure if the bottle on the MK4 is the same as the MK5 - it does look the same)
Its not particularly hard to do, the hardest part i found was taking care not spill the coolant.
Hope this helps
Rich
Offline QD MBE
  • -Receive: 102
« Reply #4 on: November 10, 2010, 06:17:49 pm »
Hope this helps
Rich
x2.
I replaced one on my MK4.
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: November 10, 2010, 08:15:35 pm »
Andrew part number is 1K0 121 407A its about £16 from VW takes about 30 mins to change and its held in by 2 torx screws and the coolant hoses.
Darren
Offline Norbreck21a
« Reply #6 on: November 11, 2010, 08:01:54 am »
Cheers Darren,
I'll get one ordered today.
BTW, I assume that the new expansion tank comes with the level sensor pre-installed ?
Offline mortygttdi
  • -Receive: 146
« Reply #7 on: November 11, 2010, 12:50:09 pm »
Yes comes moulded into the bottle mate :happy2:
Darren
Offline Norbreck21a
« Reply #8 on: November 12, 2010, 07:57:30 pm »
Sorted, thanks for the part number Darren. Even managed to get some discount so it only cost £14.10
Only problem is the pure white of the new bottle really shows up my dirty engine bay. Must get round to giving it a clean  :grin:
