Author Topic: THS Replacement FR3 Engine Mounts TFSI : Review  (Read 43079 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=6cr4ug7vu7eak7np364ng79inl&/topic,19740.0.html
Re: THS Replacement FR3 Engine Mounts TFSI : Review
« Reply #15 on: July 08, 2011, 09:39:02 am »
I find that most of the wheel hop it caused by the ESP system.
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #16 on: July 13, 2011, 10:07:57 pm »
I fitted the fast road vwr engine mount 2 weeks ago, had it on 3 days and then removed it, the vibration was driving me crazy
I think it is a dsg thing because the manual versions dont seem to suffer this ?
it feels like the clutch is at biting point on tickover when your in gear (the only way to explain the vibration) no probs on the move and feels more responsive,
i have now fitted the standard rubber mount with the fast road poly insert to stiffen it up thinking that it wouldnt vibrate as much as the ally version vwr mount, but it feels just the same, will have to get use to it methinx
neil, i'd been having increased vibration issues on the rocco after the coilies went on with the vwr lower nount, turned out the oem top mounts were well past there best, i've swapped the top mounts to VWR and strangely the car is now more refined and the vibration has been significantly reduced, in reality Geordie highlighted this on his tsi rocco  :happy2:
« Reply #17 on: July 13, 2011, 11:07:24 pm »
Same as me as when I fitted the lower race mount the car growled like mad but after the I had the side ones fitted the noise was less
Offline james
« Reply #18 on: July 15, 2011, 05:08:47 pm »
just to let you know, there is a group buy on these
http://www.mk5golfgti.co.uk/forum/index.php/topic,32106.0.html
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #19 on: March 05, 2012, 07:33:13 pm »
fantastic review !!
 :happy2: :happy2: :happy2: :happy2:
"You get what you pay for."
Offline 56OctyVRS
  • -Receive: 72
« Reply #20 on: June 11, 2012, 09:51:41 am »
I fitted my set yesterday apart from the lower engine mount. I am impressed at the improvement they have made to the egear change and thrttle response. Plus the engine has an M3 type induction growl now. Just need to get the lower mount fitted. There has been no increase in engine vibration at any speed. If anything the engine feels smother than before.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #21 on: June 11, 2012, 10:04:04 am »
i found this too, but wait till you get the lower mount fitted, that is when you get the vibration! :laugh:
Offline 56OctyVRS
  • -Receive: 72
« Reply #22 on: June 11, 2012, 04:47:50 pm »
It cant be any worse than my Fabia VRS diesel with a Super pro solid lower engine mount. That vibrated but wasnt overly intrusive.
« Reply #23 on: June 11, 2012, 06:01:05 pm »
I think those sort of vibrations being talked about here are very minor - Just a buzz felt through the steering wheel but only when first starting up cold. At least, that's what the VWR engine mounts are like and they can't be that different from THS.
Offline 56OctyVRS
  • -Receive: 72
« Reply #24 on: June 12, 2012, 08:03:43 am »
Booked in next wednesday to have the lower mount fitted. £30 fitted, so its not worth me struggling on the driveway.
Offline JMP
« Reply #25 on: June 20, 2012, 04:39:44 pm »
I just installed the FR3 top mounts to my GTI. I already had the powerflex insert done to the dogbone mount. Well I can pretty much agree to all comments already given here, the vibrations hardly increased at all. Everything feels solid during drive. However, I still get some wheelhop. Its a lot better, but not all gone.
« Reply #26 on: June 20, 2012, 05:53:41 pm »
....It's the lower mount which should cure wheelhop, not what you are calling the "top" mounts. At least that's the way it is with VWR engine mounts.
Offline JMP
« Reply #27 on: June 21, 2012, 11:38:54 am »
I think youre right. I was hoping that the powerflex insert combined with THS top mounts (btw THS calls them "top mounts") would be sufficient, but I guess not. Since Im not a fan of dropping the subframe, is the HPA solid mount the only improved option for me? Are there any other option that is intented to work only with the bottom "puck" changed? thanks..
« Reply #28 on: June 21, 2012, 01:28:06 pm »
....I know I am right on this one - There isn't a soley poly insert made which can match the effect of a proper engine mount inserted in the subframe.
There's no harm in removing the subframe in order to fit a proper lower engine mount - It does need the right tools though.
Btw, the term "top mounts" is usually interpreted to mean those relating to suspension. I think THS have got it wrong there.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #29 on: June 21, 2012, 02:49:45 pm »
Keep in mind a solid  lower mount will increase engine vibrations more than the FR3 top mounts.
Modding a car is a great compromise. Whatever you do you have to make a decision between
reliability, sportiness and comfort (+ cost).
