Author Topic: Space saver tray.  (Read 1836 times)
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Space saver tray.
« on: November 10, 2010, 06:31:41 pm »
Should there be a screw driver & a couple of spaners in there with tool for removing the nut covers & towing eye etc please as i think mine are missing due to a couple of empty slots. :rolleye:
Offline kevinm
  • -Receive: 25
  • No. 728
Re: Space saver tray.
« Reply #1 on: November 10, 2010, 07:18:28 pm »
I have a screw driver, tow eye, jack, wheel brace, lock nut and the little pull to remove the caps from the wheel bolts. I havnt noticed a spanner (it could be there).
The big slots are for storing the removable tow bar :happy2:
« Reply #2 on: November 10, 2010, 07:20:05 pm »
Have a lool in your manual. It'll tell you everything you need to find in the spare wheel area. You need a wire tool to remove wheel bolt covers. A locking nut key adaptor. A short wheel brace to remove the bolts. A screwdriver for removing the frong fog light covers. At least one (can't remember if there's two) towing eye. Probably forgotten something.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #3 on: November 11, 2010, 02:00:32 pm »
Looks like screwdriver is missing then,thanks guys. :smiley:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #4 on: November 12, 2010, 08:11:48 am »
I think the screw driver was dropped from MY06 onwards (or is it the spanner thats was dropped?).  I have the screwdriver, the end of the handle is designed to allow you to screw the wheel bolts out / in (tightening is with the wheel brace obviously).  But, its a flat bladed screwdriver, no use for removing the phillips screw holding the front tow eye cover in ... as I discovered at the bottom of an icy slope when a tractor was going to tow me up!
Sepang Blue S4 BE Avant
« Reply #5 on: November 12, 2010, 10:11:01 am »
The screwdriver shoukd be reversible - you pull out the metal bit from the handle, swap it round and slot it back it. Try it.
Offline maf
« Reply #6 on: November 12, 2010, 11:27:24 am »
 :smiley:i got a kettle, a toaster AND a coffee machine in mine  :scared:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #7 on: November 12, 2010, 11:57:01 am »
 :congrats: :ashamed:
Offline QD MBE
  • -Receive: 102
« Reply #8 on: November 12, 2010, 01:13:40 pm »
That has got to be a Boatload of fail that has just landed!
 :fighting2:
therefore - Fail is now in stock!
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #9 on: November 12, 2010, 05:03:04 pm »
 :fighting2:
:booty:  :signLOL:
