Author Topic: Anyone using a Multimedia box with MFD2?  (Read 1599 times)
« on: November 11, 2010, 12:22:33 pm »
As above... which one are you using and does it do video in motion?
Offline Norbreck21a
Re: Anyone using a Multimedia box with MFD2?
« Reply #1 on: November 11, 2010, 12:47:35 pm »
Rich,
Mine was a generic one from Fleabay about 4 years ago. Certainly did do video in motion but only when 12v is applied to the third wire (i.e. via a hidden switch). Think most of them on the bay now still work the same way.
Pretty easy to wire up.  :happy2:
« Reply #2 on: November 11, 2010, 01:00:53 pm »
Did you take power from the fuse box or from the radio loom? Im trying to make it as removable as possible for obvious reasons!
The plan is to run an apple TV thru the media box!
Offline Norbreck21a
« Reply #3 on: November 11, 2010, 01:40:47 pm »
Rich,
As I wanted the multimedia box to be powered only when the MFD2 was switched on (no point otherwise), I wired the permant Live to the CD changer socket (on the back of the MFD2) 12V out, so that only when this pin saw power did the unit power up. The earth was taken from the main MFD2 earth coming in, and the final 12V for video in motion (VIM) was taken from the cigarette lighter. I fitted an override micro switch inside the ashtray, and the lighter feed was the closest. The swtich was very convenient for switching the VIM on or off.
In fact the switch is still fitted (see below).
Car looks stock and unless you knew where the switch was, you would never spot it.
Edit: I've just checked and the CD changer power was Terminal 4 of Connector 6 (CD Changer) - "CD changer, voltage supply, positive, terminal 30"
« Last Edit: November 11, 2010, 01:48:52 pm by Norbreck21a »
