Author Topic: Milltek resonated exhaust  (Read 5250 times)
Offline Howardvwgolf
« on: February 16, 2009, 04:23:22 pm »
Thinking of getting an exhaust for my mk5 GTI, wanted peoples opinions/reviews on the milltek cat back exhaust (resonated) as awesome gti have got them at a good price at the mo. Is it much louder than standard? and does it make a droning sound which is audible inside the car which would be annoying after a while? or do i go the the non resonated and let people know im about? :grin:
any help appreciated
This one.....
http://www.awesome-gti.co.uk/product.php?xProd=6100&xSec=152
« Last Edit: February 16, 2009, 04:26:54 pm by Howardvwgolf »
Offline E30m3
Re: Milltek resonated exhaust
« Reply #1 on: February 16, 2009, 04:36:16 pm »
Even the Miltek NoN resonated does not drone !
I would avoid the resonated and go for the Non resonated , it sounds way better and is not chav in the slightest, sounds like a proper exhaust should, ie stock sound when pootling along but sounds like a beast under load  :smiley:
« Reply #2 on: February 16, 2009, 04:41:14 pm »
I don't think you'll be able to tell the difference with the resonated. But if that's what you want then go for it  :happy2:
« Reply #3 on: February 16, 2009, 04:47:38 pm »
hhmmm, well sounds like the non res would be fine then!! and awesome have got it for £341.01 with free delivery!!
I have got a pit at work i could park the car over and im quite handy with a spanner, are they relatively simple to fit, does the milltek use the same hangers and other fittings as the standard exhaust?
Offline E30m3
« Reply #4 on: February 16, 2009, 04:50:11 pm »
Should do, but i think VW weld the centre pipe to the backbox ?
Im not sure so dn't qoute me but my Edition 30 backbox was welded to the centre pipe ?
Non Res is definatly the way forward , did you try Emailing Milltek personally for there price + fitting ?
Offline GTIjames
« Reply #5 on: February 16, 2009, 05:03:00 pm »
i have got the resonated one with the full turbo back downpipe and the noise is all good, especially when you boot it which is when you want it to sound meaty!
a few people have swapped there non-res for res due to noise issues and boomy/droning sounds when on motorways
others have done the exact opposite as the res was not loud enough
each to their own,
you going for just the cat back or are you thinking turbo back as well?
« Reply #6 on: February 16, 2009, 05:13:32 pm »
Hey Howard we have a group buy going on at the minute check it out. http://www.mk5golfgti.co.uk/forum/index.php?topic=1847.0
Milltek are the number one no question, But these are top quality as well.
« Reply #7 on: February 16, 2009, 05:36:52 pm »
As James says, it's very much down to personal likes/dislikes - sound is very subjective and we all have slightly different ranges of hearing anyway (not a lot of people know that).
You can easily swap around the centre Res and Non-Res sections (at extra cost of course) if you want it quieter/louder.
Milltek zorsts mature as they coke up and you probably will experience some 'drone' at about 3,200 revs but it will pass.
VAG have a reputation for very tightly fixing and so be prepared! One of my fixings had to be drilled out!
If you are likely to remap in the future then get a Turbo-back (aka Hi-flow+Downpipe), otherwise you won't exploit the remap and vica-versa.
HTH
« Reply #8 on: February 16, 2009, 06:12:56 pm »
will have to have a look at how it all fastens together then before i go to far, not keen on letting many of the garages round my area do it as have got some right monkeys!! like to see for myself how it all goes together if you know what i mean!
I was only looking at the cat back as wasnt thinking of having a remap, maybe an induction system of some description and thats about it, which opens up another can of worms.... carbonio, APR ,Dbilas, neuspeed, the list is endless!!
« Reply #9 on: February 16, 2009, 06:27:29 pm »
Beware, Howard!! It's a very slippery slope and we're all here to help you spend your hard-earned money! :evilgrin:
Offline QD MBE
  • -Receive: 102
« Reply #10 on: February 16, 2009, 06:52:39 pm »
On thread, but just another thought.  My complete Non res,  (also supplied with a cracked Centre box, that I will be able to repair............) Is due to arrive tomorrow.
Do you have to cut the old exhaust to remove it?  On my old Golf MK4, I had to cut the Std exhaust between the two boxes to remove it.
Any thoughts?
 :happy2: :happy2:
  • -Receive: 291
« Reply #11 on: February 16, 2009, 07:32:01 pm »
There's a vid on youtube about milltek res v nonres. Originally, I was thinking about a res but once I saw that vid, I'm swung over to non-res. Need to hear them both fitted to a mk5 from the inside to the outside to appreciate the differences.
« Reply #12 on: February 16, 2009, 07:49:17 pm »
You're very welcome to ride in mine next time we meet, stealth :happy2:
I got Non-Rez.
  • -Receive: 291
« Reply #13 on: February 16, 2009, 09:06:01 pm »
Thanks!  :happy2:
Will definitely take you up on that offer.
« Reply #14 on: February 16, 2009, 09:14:26 pm »
I'm at JKM on March 7th for the Dyno-Day if it helps.
