Author Topic: RNS 510 V7 maps out yet?  (Read 19986 times)
Offline Neimad
Re: RNS 510 V7 maps out yet?
« Reply #45 on: November 18, 2010, 09:16:26 am »
Sounds cool -- I'd certainly be interested in getting all this functionality, the full postcode input alone is a killer feature!
I want... I want!  :drool::party::jumping::happy2:
Offline Sunglasses Ron
« Reply #46 on: November 18, 2010, 10:22:46 am »
How do I know what version/fireware my RNS is? Not in to all the technical malarky.. Car was registered in April 08 if that helps..
« Last Edit: November 18, 2010, 10:25:08 am by Sunglasses Ron »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #47 on: November 18, 2010, 10:24:55 am »
If test mode is enabled then just press and hold setup for about 30 secs
If not you will have to enable it with VCDS :happy2:
Offline TonyZed
« Reply #48 on: November 18, 2010, 08:04:37 pm »
Will this work with RNS version C from a Skoda (in my Golf) I am on 2660 firmware.
And, of course, where can I get a copy?
TonyZ
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #49 on: November 20, 2010, 11:31:35 pm »
Just to clarify, you install it how??  :smiley:
Sorry for the noob question  :laugh:
Over the top mod list ;o)
Offline damoegan
« Reply #50 on: November 20, 2010, 11:33:30 pm »
Put RNS 510 on map/nav > insert V7 disc > confirm loading of new map  :smiley:
Offline Rhys
« Reply #51 on: November 21, 2010, 04:17:17 pm »
Awesome!  i want, as was a bit of a mare sometimes with limited postcode search.  anyone on here dpoing the disc?
erniem
« Reply #52 on: November 25, 2010, 03:51:22 pm »
Yep all working and fully up to date thanks  :happy2:
A Skoda/Seat version of the map is being worked on as we type.  :fighting2:
what would a poor grovelling Skoda owner have to do to get a copy of the masterpiece
Offline winrya
« Reply #53 on: November 27, 2010, 05:42:35 pm »
What firmware you guys running?  I think I'm on 1100 and after upgrading to new maps I'm getting the maps and speed cameras but no full post code search :sick:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #54 on: November 27, 2010, 05:43:39 pm »
Hmmm i would try updating to at least 2680. :happy2:
Offline winrya
« Reply #55 on: November 27, 2010, 09:48:41 pm »
Mmm doesn't that put me in battery drain territory?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #56 on: November 27, 2010, 09:57:03 pm »
What year is your car?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #57 on: November 27, 2010, 10:06:57 pm »
As long as you have a K revision or higher Can Gateway you will be fine.
If not you can get modified firmware which stops the battery drain but not sure how this will work with maps or if it works at all. Those that have tried it apparently it works for them. But I haven't tested it myself.
Offline Norbreck21a
« Reply #58 on: November 27, 2010, 10:50:43 pm »
If I may ask, where are you guys getting the V7 maps - from the stealers or has someone found a download location ?
Offline M44NTU-3.2
« Reply #59 on: November 27, 2010, 11:38:34 pm »
can a r32 owner pleaaaaaaaaaaaaase get it aswelll!!! its a mk5 lol thanks!!!
MKV R32 DSG
