Author Topic: convert lambda to AFR  (Read 10590 times)
Offline Janner_Sy
  • -Receive: 113
« on: November 15, 2010, 06:01:37 pm »
guys what the fasctor you multiply the lambda readings by to get your AFR?
i have 14 in my head for some reason!!
cheers
sy
Re: convert lambda to AFR
« Reply #1 on: November 15, 2010, 07:49:06 pm »
Offline damoegan
« Reply #2 on: November 15, 2010, 08:01:13 pm »
14.7  :smiley:
Offline PDT
  • -Receive: 142
« Reply #3 on: November 15, 2010, 09:04:09 pm »
AFR is a far more precise factor as it has a higher resolution than Lambda.
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: November 15, 2010, 09:33:26 pm »
in your opinion, what do you reckon is the optimum AFR for the TFSI?
Offline Poppa Dom
« Reply #5 on: November 15, 2010, 10:41:47 pm »
Good question - have often wondered this myself - depends on the atmospheric conditions on the day, but I reckon 12.1-12.2?
Offline PDT
  • -Receive: 142
« Reply #6 on: November 16, 2010, 08:39:34 am »
Under what type of conditions? Cruise, light throttle, idle, WOT, etc.... Ideally around 14.4 at cruise/ idle and 11.5-12 under load, also look at exhaust gas temps as well as AFR.
  • -Receive: 453
« Reply #7 on: November 16, 2010, 03:59:02 pm »
I was led to believe just under 12 at top rpm was ideal.
Offline Janner_Sy
  • -Receive: 113
« Reply #8 on: November 16, 2010, 04:43:57 pm »
on a dyno for example where it is ran at WOT for the ful RPM.
Whats the threshold where it makes safest peak power/torque for example a track day, and then a lower safer setting for daily usage?
Offline PDT
  • -Receive: 142
« Reply #9 on: November 16, 2010, 05:15:55 pm »
Theres no real rule to follow, some engines will make more power at a leaner mixture than others, its not an exact science. A naturally aspirated engine can sometimes make more power at 13afr but the leaner you go, the hotter the egt's get and can cause you to retard the ignition timing slightly, which in turn can lose you the power you gained by leaning the mixture, its all about trial and error and testing.
Offline Janner_Sy
  • -Receive: 113
« Reply #10 on: November 16, 2010, 05:40:15 pm »
in regards to the TFSI then?
what do you aim for in your ed30, if yu were to give it agressive settings for a track day?
Offline PDT
  • -Receive: 142
« Reply #11 on: November 16, 2010, 10:11:18 pm »
If i was mapping a tfsi I would aim for around 11.5afr and then keeping a close watch on the egt's. If egt's get high then i would richen the mixture a touch and retest.
Offline Cupra R
  • -Given: 18
« Reply #12 on: November 17, 2010, 04:47:52 pm »
are you guy's logging MB 031 for a Lambda reading then multiplying it by 14.7 to get AFR?
Offline Janner_Sy
  • -Receive: 113
« Reply #13 on: November 17, 2010, 05:42:40 pm »
yes mate.  it was the 14.7 factor i wasnt sure about
Offline Cupra R
  • -Given: 18
« Reply #14 on: November 17, 2010, 06:05:41 pm »
 :happy2: Thanks mate, I've been doing quite a few of these log's recently too and I just wondered if I were doing it correctly  :signLOL:
