Author Topic: Pansonic TV sound through LG DVD home cinema system  (Read 1518 times)
Offline Pablos007
« on: November 19, 2010, 03:02:59 pm »
Normally I am ok with connecting home electronics but I haven't sorted this one yet.  Trying to get the audio output from a Panasonic TX-P42G20B through to the speakers on a LG HT805TH 5.1 DVD home cinema system.  I have HDMI and Optical cables connecting the two of them, but there must be a menu setting on the tv or dvd that I need to change to allow the audio to be output via the dvd speakers.   :ashamed:
Any ideas where I can look?
Offline S2 Ant
  • -Receive: 21
Re: Pansonic TV sound through LG DVD home cinema system
« Reply #1 on: November 19, 2010, 03:12:52 pm »
Can you not feed everything to the surround sound then send the picture on to the TV instead of the other way around?
Ant
Offline Pablos007
« Reply #2 on: November 19, 2010, 03:56:40 pm »
Thanks.  According to the manual it should work with the current cable arrangement, but I'll look into routing it through the surround sound and see if that solves it.
Offline Bane
  • "I was born a handsome man and now I'm half a goat
« Reply #3 on: November 19, 2010, 04:05:58 pm »
I have a Panasonic Plasma TV and Panasonic DVD player with 5.1 surround system connected by HDMI leads.
I found that in order to get sound output from the TV or SKY+ box thru the DVD and SS,I have to set the DVD player to AV,otherwise there just isn't any sound signal.
Dunno if this helps,but it's worth a try.
« Reply #4 on: November 19, 2010, 11:16:44 pm »
May sound daft, but do you need a HDMI output from the TV and not an input or are they 2 way transfer cables?
Offline Pablos007
« Reply #5 on: November 21, 2010, 07:36:55 pm »
Will try switching the cables around tomorrow when I get home.
Hurdy - My understanding was that the optical cable would allow the audio output to be routed to the DVD unit.......  :confused:
