Poll
What intake are people running??
Standard
Carbonio (incl. copies)
Evoms
Neuspeed
BSH
ITG
Forge Twintake
Other
BDM intake ;o)
Dbilas
Author Topic: Which intake are you running??  (Read 14960 times)
Re: Which intake are you running??
« Reply #15 on: November 20, 2010, 05:26:10 pm »
I'm happy with it seems to perform aswell as the rest :happy2:
....And that's where the other considerations influencing choice come into play such as sound and appearance   :happy2:
Offline Rhys
« Reply #16 on: November 20, 2010, 09:34:58 pm »
I'm toying with the idea of buying something though not sure what to get!  Does the twin take fit with the standard engine cover?  Carbonio looks the best by far!
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #17 on: November 20, 2010, 09:46:11 pm »
If you want oem look you want the Carbonio. The rest will require you to modify the engine cover beyond repair to fit with them on the car.
I have had the Carbonio on my car for 40.000 km and can't fault it, i just had a modding itch that needed scratching so i went for the twintake.
i growls from 2k to 3,5 k rpm, and with an aggresive right foot you get wastegate judder and DV blowing, so a bit more personality with the twintake than the carbonio. IMO  :wink:
Over the top mod list ;o)
Offline Rhys
« Reply #18 on: November 20, 2010, 09:51:55 pm »
True i know what you mean, also the twin take is a bit more expensive.  I think if i dont go Carbonio i may go ITG.  Does the Carbonio sound/notice much different from stock?  As i may get a remap at same time.
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #19 on: November 20, 2010, 10:22:04 pm »
Nothing whatsoever Rhys, if you're looking for sound/performance gains I wouldn't even think about the Carbonio twice! I made this mistake too.
All it does (and even this isn't proven) is perhaps increase MPG by about 1/1.5MPG as it allows the engine to breathe slightly better. That's the only small change I've noticed. It's just to look good under the bonnet really  :indifferent:
Pete
Offline Janner_Sy
  • -Receive: 113
« Reply #20 on: November 20, 2010, 10:30:12 pm »
first mod i ever did was the carbonio.  may as well have smoked the pound notes, as it made sweet FA difference.
@RDFCpete id bet those difference were a result of the panel filter.  and not the carbonio scoop.
« Reply #21 on: November 21, 2010, 10:45:47 am »
I started off with the Carbonio before the Twintake and I agree with everything said. No regrets, but the Carbonio only improves efficiency and is cool eye-candy.
I adapted an Evoms engine cover to go with my Twintake:   http://www.mk5golfgti.co.uk/forum/index.php/topic,11702.0.html
It's also possible to modify an oem plastic cover as NeilM so expertly did. Search the How-To section?
« Last Edit: November 21, 2010, 10:47:32 am by RedRobin »
Offline Rhys
« Reply #22 on: November 21, 2010, 10:58:10 am »
Ok so the twin take and the ITG is the best?  But has anyone, or can you modify the engine cover so it looks fairly standard under the bonnet?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #23 on: November 21, 2010, 11:08:56 am »
You mean like this?
« Reply #24 on: November 21, 2010, 11:10:53 am »
....As I said in the post above yours:
Also search the Cosmetic Modifications section  :smiley:
Offline Rhys
« Reply #25 on: November 21, 2010, 03:45:59 pm »
Cool cheers!  nice to see it is possible.
Dont wish to hijack thread, but going to ask 1 question whats best first air filter or Exhaust system?  As i got money for remap, just dont know wether to spend £350 on filter or wait and find nice second had miltek for a couple 100 more?  just cant afford to do both.
« Reply #26 on: November 21, 2010, 03:59:29 pm »
....I think I'd be inclined to do the exhaust first, then remap, and air intake later - That's what I did. Someone please correct me if I'm wrong but I think a high-flow exhaust will probably indirectly help any intake's breathing rather than vica versa, but I might be talking rubbish.
Offline Janner_Sy
  • -Receive: 113
« Reply #27 on: November 21, 2010, 04:33:50 pm »
im with robin on this one.  however if your after gains it needs to be the downpipe+sports cat and not the cat back exhaust section.  the only thing with the exhaust is you will need an extra £50 to go straight onto the stage 2 map.
i really wouldnt bother with the cat back at all until you have finished everything else on the car. its more of a garnishing modification.
As above, the exhaust requires a different map ideally, whereas the intake can be added at any time with no map tweaking required as the ECU can adjust enough to compensate for it
« Reply #28 on: November 21, 2010, 04:59:19 pm »
....Agreed but I would add that if an aftermarket intake is adding significant power and you are running a stock fuel pump and don't want to spend on replacing it, you may want to consider a map such as Revo which allows you to turn down a B/T/F setting to compensate.
Offline Janner_Sy
  • -Receive: 113
« Reply #29 on: November 21, 2010, 05:03:24 pm »
not really.  none of the maps seem to suffer with fuel cut any more, with the exception of revo when the settings are yanked up.  I never had any isue on shark stage 2 or bluefin stage 2 with an ITG added after
