Author Topic: speedo broke  (Read 1529 times)
Offline Russ_leeds
speedo broke
« on: November 21, 2010, 10:24:05 pm »
hi all
my speedo and display have stopped working. is this likely to be a fuse?
cheers
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline Russ_leeds
Re: speedo broke
« Reply #1 on: November 22, 2010, 07:05:00 pm »
any ideas?
Offline TrickGTI
Re: speedo broke
« Reply #2 on: November 22, 2010, 07:07:36 pm »
My display has gone off twice in the 9 months iv owned it but it comes back on usually... id say the cluster has or is packing up as if the rev counter is working and other lights on the dash are then it wont be a fuse....
2006 Tornado red GTI
Offline Janner_Sy
  • -Receive: 113
Re: speedo broke
« Reply #3 on: November 22, 2010, 07:24:17 pm »
its probably a fuse if everything is gone.  be aware though, i think it might be illegal to drive a car with non operating speedo.  you might have to use a sat nav for the time being to stay legal
Offline kevinm
  • -Receive: 25
  • No. 728
Re: speedo broke
« Reply #4 on: November 22, 2010, 07:27:00 pm »
If you have vcds you could do an output test on the cluster to see if its goosed...
Offline Russ_leeds
Re: speedo broke
« Reply #5 on: November 22, 2010, 11:59:57 pm »
yeah its everything thats gone. i use a van for work so not a problem dont really need it till the weekend. does any1 know whick fuse it would be?
cheers
Offline cartwheel
Re: speedo broke
« Reply #6 on: November 23, 2010, 12:18:21 am »
Can't help re the speedo, but theres a trick with the dual climate controls where the right hand display will show your speed. Might get you out of trouble till you get it sorted.
Think you hold 'econ' and the 're-circulated air arrow' buttons together, turn the left control clockwise until the left hand display shows 19-0, turn the centre control clockwise once until the display shows 19-1, now the right hand display will show a corrected mph speed. To come out of this function just press the 'econ' button again.
I'm sure if thats not spot on someone will correct me!
Offline Russ_leeds
Re: speedo broke
« Reply #7 on: November 23, 2010, 05:07:10 pm »
yeah cheers m8 i no that trick :signLOL:
