Author Topic: Am i going mad??????  (Read 3362 times)
Offline richtung
  • -Receive: 56
« on: November 22, 2010, 07:02:49 pm »
Hi Folks,
Just wanted to pick your brains.
Basically, finished work, driving home, the tyre pressure warning symbol illuminates on the dash. Pull into supermarket car park and check tyres - passenger rear is very low on air. I top up tyre,  make way to tyre garage to get it repaired.
Anyway, the car is unlocked as ive just gone into the boot to get the locking wheel nut and the little tool to removed the wheel nut covers. chatting away to tyre guy when i look up and see all the windows are down!!
when i got home, i tried to replicate the same scenario to no joy.
Ive disabled the remote windows open/close function just in case - i dont think ive ever used it anyway.
The only explanation i can think of is as i was kneeling down to remove the wheel nut covers, the car key in my pocket my have been pressed thus opening all the windows.
Anyone have any meaningful theories/explanation?
Richard
Offline Russ_leeds
Re: Am i going mad??????
« Reply #1 on: November 22, 2010, 07:04:39 pm »
i think its a common fault mate. a few on here have had problems with the windows opening them selves
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
« Reply #2 on: November 22, 2010, 07:05:28 pm »
I agree with your hypothesis..   :smiley:
Offline 182_blue
  • -Receive: 54
« Reply #3 on: November 22, 2010, 07:31:27 pm »
Oddly I did exactly the same when I removed my wheels the other week, and yes it was my keys being pressed as I knelt  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: November 22, 2010, 07:34:46 pm »
loads of guys on briskoda had the window opening issue.
Offline Lyons
  • -Given: 18
« Reply #5 on: November 22, 2010, 08:22:03 pm »
Can't help, but my tyre pressure light came on today for the first time too!
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #6 on: November 22, 2010, 09:12:23 pm »
..........mine did it once,no puncture etc.Re-set switch next to gear stick & it's never done it again ? very strange.
Offline Lyons
  • -Given: 18
« Reply #7 on: November 22, 2010, 09:15:01 pm »
Ah, do you just press that switch to get the light off?
« Reply #8 on: November 22, 2010, 09:43:16 pm »
....You experienced a deep and meaningful moment on seeing a passing female and had a hard-on  :evilgrin:
I've done the same - Involuntarily pressed the key, that is - It's easily done in a tight trouser pocket.  :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #9 on: November 22, 2010, 10:20:29 pm »
.........hold it down for a few seconds & it should ''beep'' & light should go out  :happy2:.
Offline Lyons
  • -Given: 18
« Reply #10 on: November 22, 2010, 10:44:44 pm »
Sweet! I'll double check the pressures tomorrow then whap it off.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=lhlcjcsuku8v433ct30geu0li1&/topic,19740.0.html
« Reply #11 on: November 22, 2010, 10:50:09 pm »
You never disappoint!  :love:
« Reply #12 on: November 22, 2010, 10:58:30 pm »
Trust me Rich. Sometimes he does  :wink:  :signLOL:
« Reply #13 on: November 22, 2010, 11:12:50 pm »
....Now now! Just because I wouldn't let you play with those anal beads.
Offline 08micsta
  • -Receive: 63
  • Smart Fortwo 600cc
« Reply #14 on: November 23, 2010, 06:18:35 am »
Not a major problem...
Take the car to VW and get them to update the software on the CCM Module.
The Central Convenience Module (CCM) controls all electronics such as electric windows, mirrors etc etc etc. Now the module itself is German. However the software that runs the windows is American... Catching onto the problem here?
VW simply replaces the software with what i call a "truce" software. It stops the bickering and takes no more than an hour to copy over.
Voila - Problem solved.  :notworthy:
Mike
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
