Author Topic: petrol in a diesal  (Read 2452 times)
Offline divweir
petrol in a diesal
« on: November 26, 2010, 05:11:41 pm »
looking for a wee bit of advice   friend just put 50 petrol in a nissan 4x4  drove it for 2 mile now its stoped what you guys think   i think it will need a new engine
Sig to big.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: petrol in a diesal
« Reply #1 on: November 26, 2010, 05:17:34 pm »
50 petrol ? 50p worth?.
Offline divweir
« Reply #2 on: November 26, 2010, 05:26:44 pm »
50£ petrol but was half full of diesil
Sig to big.
« Reply #3 on: November 26, 2010, 05:35:01 pm »
my mate did this on his nissan patrol..i drained the tank,cleaned all the fuel line out and also changed the fuel filter and his has been fine...some times it can burn the tip of the injectors of but in 20 years i haveonly seen this done once
Offline divweir
« Reply #4 on: November 26, 2010, 05:51:22 pm »
rac came said should be ok 29.50 to drain
Sig to big.
Offline neg
  • gone old skool
« Reply #5 on: November 26, 2010, 05:53:11 pm »
I did this in a GTI Anniversary TDI  :ashamed: - not £50 but half a tank on top of diesel - I was on the was to cornwall so a 250mile tip, everything went fine, maybe a little more smoke occasionally.  The biggest problem you have is when you turn it off, you'll struggle to start it again - I stopped at service about 125mile in and it took an age to fire up, once it was up it was fine - I then brimmed it again with diesel to water down even more and it was fine from then on...
« Reply #6 on: November 26, 2010, 06:24:03 pm »
My mates missus did this on a Jeep Cherokee and then drove for 40 miles.
My mate drained it, changed the fuel filter and in his case the fuel pump, as it uses the diseasal as lube, and all was fine. :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #7 on: November 26, 2010, 06:35:34 pm »
i was under the impression if you put petrol in a diesel it wasnt that bad unless you leave it for a while before draining, however i think if you put diesel in a petrol it cocks the engine up.`
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #8 on: November 26, 2010, 07:28:25 pm »
a small amount of petrol in a diesel isn't too bad, they actually used to use a petrol diesel mix at very low temperatures to help keep the diesel viscous, think the issue here is the volume or percentage of petrol, as said above should be fine once its drained and filters changed, tell your mate to get one of those special fuel flaps installed that stops you putting petrol in a diesel!
Offline divweir
« Reply #9 on: November 26, 2010, 07:55:57 pm »
yes the flaps  the only problem with them is you cant use a fuel can on them
hope the car will be ok rac man said hes done a few nissan 4x4 and they have all been
ok   theres  more people put wrong fuel in than you think   not me of course :signLOL:
Sig to big.
« Reply #10 on: November 26, 2010, 08:22:21 pm »
old diesel engines was fine years a go to put a bit of petrol in a diesel in the winter to stop it freezing but modern diesel engines have come along way since then
Offline neg
  • gone old skool
« Reply #11 on: November 26, 2010, 08:52:33 pm »
you shouldnt be able to put diesel in a petrol nowdays as the nozzles are different sizes so they dont fit - on newer cars anyway
Offline divweir
« Reply #12 on: November 26, 2010, 08:55:15 pm »
it was a nissan qashqai three year old i think
Sig to big.
« Reply #13 on: November 27, 2010, 12:20:24 am »
that what the idea was the nozzles are supposed to be different but they do fit each other still
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #14 on: November 29, 2010, 09:15:28 am »
you will struggle to get a diesel nozzle in a petrol car as its bigger but its still possible the other way round!  As you say Maxitrol not advisable to put petrol in a modern diesel, I was trying to reassure the OP that its not a huge issue with the way compression engines work.  :happy2:
