Author Topic: Warning Bongs  (Read 6385 times)
Offline els904
Warning Bongs
« on: November 28, 2010, 10:18:33 am »
My Golf now no longer sounds bongs to accompany warnings like low external temperature, excessive speed, low washer fluid etc. - The warnings appear on the display with warning lights where appropriate, but no sound. However, the seat-belt warning still pings. Is this a fault, or have I inadvertently turned the sound off. If so, how do I turn it back on? Can't find any mention in the handbook.
Thanks,
Peter
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: Warning Bongs
« Reply #1 on: November 28, 2010, 09:04:55 pm »
I don't think my car gives an audible warning either - apart from the visual warning that comes on the MFD display.
Re: Warning Bongs
« Reply #2 on: November 28, 2010, 09:08:07 pm »
 :popcornsoda:
Offline apollo13
  • -Receive: 47
Re: Warning Bongs
« Reply #3 on: November 28, 2010, 09:10:41 pm »
I get a 'bong' when the low temp warning comes up. Although when I disabled the seat belt chime thriough VCDS I lost it......
  • -Receive: 291
Re: Warning Bongs
« Reply #4 on: November 28, 2010, 09:26:34 pm »
I disabled the seatbelt warning but still get bongs for cold weather/low tyre pressure etc.
Offline apollo13
  • -Receive: 47
Re: Warning Bongs
« Reply #5 on: November 28, 2010, 10:00:19 pm »
Strange mine only came back when I turned the seat belt warning back on... although my cluster is U.S spec
The seat belt chime goes off before you get in the drivers seat!
  • MUBster DUBster
Re: Warning Bongs
« Reply #6 on: November 29, 2010, 10:30:31 pm »
May be  the bongs don't happen if you have Recaros...I know I definately don't get the seat belt warning because of the Recaros.
Offline els904
Re: Warning Bongs
« Reply #7 on: November 30, 2010, 06:43:50 am »
Just to clarify - I used to have the bongs, they've suddenly disappeared and I don't know why.
Offline humkar
Re: Warning Bongs
« Reply #8 on: November 30, 2010, 01:50:46 pm »
I get bongs for speeding over a certain limit, never new you get bongs for tempreture! I assume when you guys talk about tempreture, you're on about the engine tempreture!
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Warning Bongs
« Reply #9 on: November 30, 2010, 02:19:27 pm »
Nope. Ambient air temperature from the external sensor reading. Sounds a chime/bong when temperature drops below 4 celcius.
Interestingly, mine still does this despite disabling the seat belt warning light/sound, just like Stealth.
Offline humkar
Re: Warning Bongs
« Reply #10 on: November 30, 2010, 03:13:57 pm »
Oh Thats funny, I always thought I heard strange bongs out of the blue. I assumed them to be my DPF filter light/warning, which I had disabled when my DPF was removed.
  • -Receive: 291
Re: Warning Bongs
« Reply #11 on: November 30, 2010, 09:45:28 pm »
There should be a flashing temperature reading on the dash to accompany the bong once the ambient temperature is below 4*C - it flashes three or four times and then stays solid.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Warning Bongs
« Reply #12 on: December 01, 2010, 09:33:41 pm »
This is designed so that a driver can set a speed warning if using winter or other tyres which have a lower speed rating than the maximum speed of the car. You should be able to disable this and alter speed threshold via your multifunction display (midline or highline both support this).
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Warning Bongs
« Reply #13 on: December 01, 2010, 09:55:11 pm »
...........& me,now just get the flashing * then it goes to a fixed *. Not bothered as you still see it & i hate those warning bongs anyway.Done for the yank market.
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
Re: Warning Bongs
« Reply #14 on: December 03, 2010, 07:45:33 am »
IIRC the bong only sounds if the temperature drops through 4 celcius whilst driving. If the temperature on start up is sub 4 degrees, there will be no sound. It's designed to alert the driver to a dropping temperature, and not if the ambient temperature is already below that at start up.
So as long as the UK remains a suburb of Siberia, no one should be hearing temperature bongs for a while. -14 here last night. :surprised:
