Author Topic: Negative rear camber in snow!  (Read 3954 times)
Offline jimmy-s3
« on: November 28, 2010, 05:55:35 pm »
Has anyone else on here got negative rear camber? My car is leathal at the moment and the only thing i can put it down to is the negative rear camber.
Whats everyone else's mk5 like at the moment??
Offline gti265
Re: Negative rear camber in snow!
« Reply #1 on: November 28, 2010, 06:03:51 pm »
mine is:
left: -1' 49
right -1'26
tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline jimmy-s3
« Reply #2 on: November 28, 2010, 06:30:33 pm »
Yeah but hows it drive on these slushy icey roads?? Mines all over the road even at 20 mph!
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: November 28, 2010, 06:55:23 pm »
what makes you think its the negative camber?????
what tyres are you using
Offline jimmy-s3
« Reply #4 on: November 28, 2010, 07:34:47 pm »
Tyres are 215/40/18 Falken 912's with 75% tread left! It feels like the rear of the car is unsteady which makes me think camber!!?
Offline Janner_Sy
  • -Receive: 113
« Reply #5 on: November 28, 2010, 07:43:29 pm »
are you aware that summer tyres significantly loose their grip once the temperature drops below 7oC.  this is even more noticeable on high performance tyres which rely on having a little more temperature in them to allow the rubber compound to work as expected.
id bet that its your tyres causing an issue.  its either that or there is something mechanically not right or set up correctly.  It really shouldnt be that bad.
what were the weather conditions this was happening in
Offline gti265
« Reply #6 on: November 28, 2010, 07:50:33 pm »
i dont no as we havent had snow here, it also happens if you let go of the accelerater half way round a corner, this can make the back end go a bit lose
are your tyres at the correct pressure??
Offline Janner_Sy
  • -Receive: 113
« Reply #7 on: November 28, 2010, 07:52:14 pm »
thats a little bit of oversteer caused by the lack of grip at the moment.
you have a very good point about the tyre pressures.  definitely worth a check, pressures drop in the cold, so you  need to increase them to compensate for the temp drops
Offline jimmy-s3
« Reply #8 on: November 28, 2010, 07:57:28 pm »
Yep, tyres are correct pressure!
Even when the temp has dropped in the past, these tyres in my opintion are great so im not sure its an issue with them.
It feels like really bad understeer but thats even when driving in a straight line and the car has been twitching from side to side when driving over slushy ice/snow even at 20-30mph on an A road!
Offline gti265
« Reply #9 on: November 28, 2010, 09:33:05 pm »
have u got underneith the car and checked theres nothing loose or taken the rear wheels of and checked everything is how it should be??
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #10 on: November 29, 2010, 09:08:02 am »
Have you had the Falkens in the snow before?  I have the FK452's and even the badly worn dunlop shytemax they replaced were a lot better in the snow.  Obviously no summer tyre is going to be at its best in the cold and snow but these seem particularly bad.
Next tyres will be european, most likely michelins, should be designed with a bit of cold weather in mind!
Sepang Blue S4 BE Avant
Offline jimmy-s3
« Reply #11 on: November 29, 2010, 09:51:40 am »
They have been fine in the past! I had a set of 452's on my last car and they also were fine!
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #12 on: November 29, 2010, 10:45:03 pm »
The twitchiness in a straight line (especially during hard braking) is a give away of too much 'toe out' on the rear wheels.  That's where the wheels are pointing outwards, i.e. \ /.
I hope that makes sense...basically you really want your rear wheels to be dead straight, i.e. | | or with a little toe in, / \.
I think this is not the same as camber though.
Offline jimmy-s3
« Reply #13 on: November 30, 2010, 07:53:44 pm »
Guess what!
Checked my rear tyres and the n/s/r tyre has worn right down on 2/3 of the inside leaving just 1/3 of the outer edge with tread!
So when ive been checking my rear tyres iv just looked and felt the outer edge!
Anyway, ive had the offending tyre replaced today and the car feels much better already. Once the snows gone im gunna have a 4 wheel alignment done!
Offline daz5182
« Reply #14 on: November 30, 2010, 10:07:34 pm »
must have been the camber and the tread mate, i have got a standard GT and it is fantastic in the snow, i have got bridgestone re070s too which aren't the best for snow....
