Author Topic: Coolant light came on this morning  (Read 1173 times)
Offline njdudsbury
« on: November 29, 2010, 12:54:16 pm »
Hi all
Im sure I've read this problem somewhere before.
Got in the car this morning -5 temeperature, started ok but then the coolant warning came on a few seconds later.
Checked the coolant and its fine. Turned off and then back on again and the warning has gone. Car runs fine.
It also did this last year when I was up North. Again is was bitterly cold.
Anybody else had this problem. Is it just a temperature thing when it gets really cold?
Any ideas?
Offline gti265
Re: Coolant light came on this morning
« Reply #1 on: November 29, 2010, 12:55:57 pm »
i had this the other day did exsactly the same as you and it was fine, i just had my cambelt done and the coolent replaced and it hasnt done it since. hopfuly it will stay that way :)
tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline Norbreck21a
« Reply #2 on: November 29, 2010, 12:57:35 pm »
Yep. frequently. It's the sensor in the coolant expansion tank that get's a little corroded.
Had this all the time when the weather was in the minus figures. Wiping the 2 probes sometimes cures it, but best bet is to just replace the coolant bottle (which comes complete with the sensor). Bought mine a coupl eof weeks ago from the stealers for £14.61. Took about ½ hour to fit, and light has never been on since (and it was -8°C here this morning).  :happy2:
Andrew
Offline S2 Ant
  • -Receive: 21
« Reply #3 on: November 29, 2010, 01:09:30 pm »
There was a thread about this a couple of weeks ago, as said, seems to be common in the cold. Just check your levels etc and you'll be fine
Ant
