Author Topic: edition 30 engine into a std GTI - straight swap?  (Read 1672 times)
Offline jmspear
« on: November 30, 2010, 03:51:14 pm »
Can I drop an edition 30 engine straing into my std Mk V GTI?
I already have an ITG so will need to change the pipework to accept the front dump valve and I guess I will have to change the intercooler pipes, I have a miltek TBE system so this should just fit striaght on.
I am currently running stage 2+ map (superchips) so I guess I will have to go to a stage 3 map - their map for the K04 conversion
I am worried that the ecu in my GTI won't work with the edition 30 lump? Surely if I just change over the various connectors it should just fire up or am I being really niave?
Any experience or insight you can point me to?
Many thanks
John
Saint Steve
Re: edition 30 engine into a std GTI - straight swap?
« Reply #1 on: November 30, 2010, 05:08:52 pm »
Pm joesgti fella , and he'll let you know what he had to go through to do his old car.
Offline PDT
  • -Receive: 142
« Reply #2 on: November 30, 2010, 06:11:07 pm »
Ecu will be fine, both are bosch ME9. just remove the ECU and send it to a specialist with a BDM tool and ask them to create a map that is equal to a standard or stg1 ed30 software version.  ( i would be happy to do this for you, £100 for a standard or £299 for a stg1 equivalent)
Other than that its pretty much plug and play!
