Author Topic: quick question......... key related  (Read 1628 times)
Offline joesgti
  • Eat my sick, Eat my sick.
« on: November 30, 2010, 06:58:36 pm »
how do you take the badge off the front of the VW key??
Offline QD MBE
  • -Receive: 102
Re: quick question......... key related
« Reply #1 on: November 30, 2010, 06:59:33 pm »
Get a sharp knife just under the edge and flick it off.
Offline joesgti
« Reply #2 on: November 30, 2010, 07:01:11 pm »
that must be impossible without damaging the emblem.? think il just but a new emblem....
Offline joesgti
« Reply #3 on: November 30, 2010, 07:06:13 pm »
just unscrewed the screw. how do you seperate the key??
Offline QD MBE
  • -Receive: 102
« Reply #4 on: November 30, 2010, 07:08:39 pm »
Offline joesgti
« Reply #5 on: November 30, 2010, 07:10:30 pm »
i already know how to do that  :happy2:
i need to dismantle the top part.
Offline QD MBE
  • -Receive: 102
« Reply #6 on: November 30, 2010, 07:16:52 pm »
Taken from the web............ :angry015:
Yes, the FOB separates. You have to pry off the VW emblem with a box blade, or some thin-type of blade so as to not scratch the emblem. Underneath, you will need a small jewel philips head screwdriver for the small screw. Take out the screw and then the pieces will separate. It is also better to have the flip opened so that the blade won't fly away!!
Further, when you reassemble, make sure you do not lose your transponder chip, AND make sure you wind the blade at least one time on the spring in order to have the tension to flip open.
This is also a GREAT way to transfer your already programmed transponder into a new FOB/Remote after you have the blade cut. Then, just follow the remote programming instructions in your owners manual.
I need to add... DO NOT DAMAGE YOUR TRANSPONDER LIKE I DID !!!.
 :smiley:
Offline joesgti
« Reply #7 on: November 30, 2010, 08:21:54 pm »
all done! cheers pal.  :smiley:
