Author Topic: Huston i have a problem  (Read 1443 times)
Offline johnboy07
« on: December 02, 2010, 10:11:33 pm »
Hi all
my new downpipe and decat came today so thought i would go and fit it seeing as i couldnt get out due to the snow.
All was going fine until i got to the last bolt on the exhaust.... it sheared straight off and then to make matters worse a pipe just below the two cooling pipes that go from the engine at the back into the car snapped as it was cold and brittle. It has a one way valve connected in series and dont no what its for but have stripped the broken bits off and now just require a bit of pipe to reconnect so no problems there.
It was really the exaust as ive fit the new and done the 3 up very tight with the new gasket and hoping it will be ok with 3. whats the chances of that being enough as its the most in accessable one and will find it very hard to drill and tap for a new bolt?
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
Offline POC
Re: Huston i have a problem
« Reply #1 on: December 03, 2010, 12:37:53 am »
Nightmare scenario mate  :sad1: Ive done this myself while changing the downpipe on an Impreza.
Look at it this way, VW made it with four studs/bolts for a reason.  It'll be a pig, it'll take a few hours to sort, but worth it in the long run for peice of mind  :happy2:
Offline PDT
  • -Receive: 142
« Reply #2 on: December 03, 2010, 03:56:13 pm »
Did this on my own gti a few years ago, i did a temporary fix and coated each side of the gasket witn a specialist silicon exhaust sealant (1500 degree stuff) and it was fine until i could get the turbo off to drill and refit a stud before selling the car.
Offline johnboy07
« Reply #3 on: December 03, 2010, 05:05:53 pm »
right ive fitted the new pipe which i didnt buy from vw as it was alot from there so made my own up. and fitted everything else and no blowing. well happy with the result. cant believe how much it pops now and its a standard rear section
Offline PDT
  • -Receive: 142
« Reply #4 on: December 03, 2010, 05:13:48 pm »
Hopefully your temporary fix will last :)
