Author Topic: heated washer jets?  (Read 9758 times)
Offline njdudsbury
heated washer jets?
« on: December 07, 2010, 09:29:56 pm »
Just a quick question.
I have the winter pack on my car and I have read somewhere that the washer jets are heated?
If so what do you have to have switched on to make them work?
Offline calculon
Re: heated washer jets?
« Reply #1 on: December 07, 2010, 09:56:58 pm »
Yes, you have heated jets. To switch them on, you just have to turn on the ignition (they are always on iirc).
Offline ILoveTuna
« Reply #2 on: December 07, 2010, 10:01:38 pm »
I know this has probably been asked previously but what does the winter pack consist of?
Offline calculon
« Reply #3 on: December 07, 2010, 10:05:02 pm »
I'm not too sure if it's the same in the UK as in Belgium, but here it consists of:
- heated front seats
- heated washer jets
- headlamp washer jets (including a larger washer fluid bottle)
-edit-
And a low level washer fluid warning light.
« Last Edit: December 07, 2010, 10:06:35 pm by calculon »
Offline jmspear
« Reply #4 on: December 07, 2010, 10:08:30 pm »
that's what it is in Sweden, as mine is a RHD import from sweden and it came with winter pack as std.
Offline ILoveTuna
« Reply #5 on: December 07, 2010, 10:12:52 pm »
Interesting, i have head light washers but no heated seats. I dont think i have heated washer jets as they have not worked for the last week in the chilly conditions!!!  :smiley:
Offline gazbutS3
« Reply #6 on: December 07, 2010, 10:19:55 pm »
I seem to remember something about the heated washers being connected to the heated rear screen, so when that is switched on so are the heated washer jets :smiley: could be talkin arse though :smiley:
Offline Norbreck21a
« Reply #7 on: December 07, 2010, 10:21:01 pm »
Funny that, I have heated seats (leather upholstery) but no winter pack, hence no heated washer jets. However even though it's been below freezing for a week now, and today's temperatures were down as low as -8 deg C, my washer jets have worked all week.
Think it's got more to do with the quality and quantity of screen wash additive in your bottle than anything else.
Nasir
« Reply #8 on: December 07, 2010, 10:26:34 pm »
Xenon lights have headlight washers, leather seats are heated.
Offline ILoveTuna
« Reply #9 on: December 07, 2010, 10:27:59 pm »
I do have xenons so thats the reason for my highlight washers.. nice one..  :happy2: :happy2:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #10 on: December 08, 2010, 09:12:46 am »
Any idea how easy the low washer fluid warning is to retrofit?  Had this on the mk4 and really miss it.  Can't understand why it wasn't standard on the mk5 ...
Sepang Blue S4 BE Avant
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #11 on: December 08, 2010, 09:41:45 am »
Saw someone comment on it, can remeber if they said you just need to fit the sensor, or if only the larger washer bottle has the hole for the sensor.... have a feeling it might have been in darrens build thread when he retro fitted his xenons!
Offline Drapoon
« Reply #12 on: December 08, 2010, 10:12:10 am »
I have the winter pack & heated door mirrors also which I assumed was part of the pack & not as standard?
If I have heated washer jets then they must be pretty cack as they haven't worked for the past week!
I do have heated seats, washer fluid level warning, headlight washer jets :smiley:
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #13 on: December 08, 2010, 10:17:13 am »
heated electric mirrors were standard buddy, not sure if mine has winter pack but as I have xenons so washer fluid warning and headlamp washers and leather so heated seats its rather hard to tell  :wink:  I have avoided washing the screen when freshly starting the car, and usually wait till engine warmed up and have been fine with the headlamp and washer jets not being frozen, but temps down in kent have only been down to -2.5 since I dug it out of the snow, so god knows how it would cope with being tup north!  :grin:
Offline dindi_boy
« Reply #14 on: December 08, 2010, 01:23:41 pm »
I've just had the car idling for half an hour in the drive to get some heat into it (it was -16 here last night) and I noticed that the panel that the headlight jets are behind is stuck out on one side of the car. The other side of the car has returned to the closed position. I tried to defrost it and push it back in but don't want to force it. Am I right in saying that the headlight jets only work when the car is moving? Any advice on how to resolve this or is it a case of seeing what happens when the car finally gets defrosted and back on the road?
Thanks everyone!
