Author Topic: Front Indicator Bulbs  (Read 4954 times)
Offline Norbreck21a
« on: December 08, 2010, 03:33:11 pm »
As they are a pain to get at to remove them, anyone know if the front Halogen headlamp unit indicator bulbs (which I know are 12V PY 21W units) are offset pin or not.
There seems to be 2 types at my local motor factor and my luck I would buy the wrong ones. I'm changing the standard orange bulbs (at last) to chrome ones to avoid that unsightly Orange effect in the light casings.
Andrew
« Last Edit: December 08, 2010, 03:37:14 pm by Norbreck21a »
Offline apollo13
  • -Receive: 47
Re: Front Indicator Bulbs
« Reply #1 on: December 08, 2010, 03:38:54 pm »
Yes Andrew they are offset pins.
120 degree I think.
Offline v2brett
« Reply #2 on: December 08, 2010, 05:40:42 pm »
i dont think you`ll lose the `fried egg` look mate as the orange part is a lense built into the light iirc
« Last Edit: December 08, 2010, 05:42:38 pm by v2brett »
Still Here!
Offline Norbreck21a
« Reply #3 on: December 08, 2010, 06:27:19 pm »
Is it Brett.... oh bugger, there goes that idea then  :grin:
Lee, thanks also for confirming the pin arrangement  :happy2:
Andrew
  • -Receive: 291
« Reply #4 on: December 08, 2010, 09:41:50 pm »
Are you sure you're doing it right? Front indicators on halogens were the easiest bulbs out of all for me to change!  :stupid:
Offline Norbreck21a
« Reply #5 on: December 08, 2010, 10:14:43 pm »
To be honest stealth I've never tried. I just assumed with the sidelights being an absolute b*tch, that the indicators may have been as well ?
Too bloody cold at the moment to mess about and find out, but I've just purchased a set of black headlights off Saint Steve, so I'll be able to have a proper look when they arrive.
Offline v2brett
« Reply #6 on: December 08, 2010, 11:39:39 pm »
[/quote]
Andrew
[/quote]
Im sure it is andrew, because i looked into the same thing a while back and found that the orange comes from a lense fitted in the light unit.  you may find the indicator bulbs are just clear bulbs when you remove them :happy2:
« Last Edit: December 08, 2010, 11:42:22 pm by v2brett »
Still Here!
  • -Receive: 291
« Reply #7 on: December 09, 2010, 04:11:48 am »
The sidelights are a pain. Even the dipped/mains are more difficult to change than the indicator lights. The indicator bulbs sit on a base which has a handle. Twist the handle, withdraw the bulb+holder, pop out the bulb and swap it. Simples.
