Author Topic: 4 motion  (Read 3329 times)
Offline matsu
  • -Given: 78
4 motion
« on: December 09, 2010, 11:46:53 am »
stupid question of the day.... what does the 4 motion mean?
 :sad1:
matsu
Re: 4 motion
« Reply #1 on: December 09, 2010, 11:49:16 am »
all 4 wheels have drive to them
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: 4 motion
« Reply #2 on: December 09, 2010, 12:12:17 pm »
isn't it basically just the haldex 4 wheel drive system like in the S3, R's etc.
Offline 94Luke
Re: 4 motion
« Reply #3 on: December 09, 2010, 02:03:13 pm »
why is it that people say it isn't 'true' 4WD? what is true 4WD in comparison?
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: 4 motion
« Reply #4 on: December 09, 2010, 02:10:09 pm »
I believe (could be wrong) that the golf etc are fwd most of the time until the front wheels loose tractiion and then the haldex kicks in and powers the rears.
'True' would be if all 4 were powered all the time.
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: 4 motion
« Reply #5 on: December 09, 2010, 03:08:46 pm »
As parks says the Haldex application in transverse engines doesn't permanently power all for wheels, power is transfered via a clutch pack to the rear wheels in a reactive fashion so an amount of slip has to occur before torque is transferred.  It also de-couples the rear wheels under braking and ESP activation to stop the individual wheel braking from upsetting the power transfer.
What people refer to as proper or full 4 wheel drive each wheel is permanently powered and power is transferred by a torsional centre diff.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=t7lsm4pe4f9ljgq1f1c3ik6nnq&/topic,19740.0.html
Re: 4 motion
« Reply #6 on: December 09, 2010, 03:16:14 pm »
Which is where 4motion or Haldex differs to Quattro!
Re: 4 motion
« Reply #7 on: December 09, 2010, 05:08:38 pm »
Shush there Rich you'll be upsetting all those S3 owners and their Quattro (not quattro) badges. :wink:
Offline 94Luke
Re: 4 motion
« Reply #8 on: December 09, 2010, 06:14:18 pm »
So under 'normal' conditions there can be no drive to the rear wheels? Though it was always a 90:10 front to rear split that changes under conditions
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: 4 motion
« Reply #9 on: December 10, 2010, 10:18:17 am »
Under normal conditions, there is a 90:10 torque split, and the haldex is capable of transfering upto 100% of torque to the rear wheels.  Its only under certain conditions when the rear wheels are un-powered to stop things like the ESP and ABS causing sudden and sporadic transfers of power across the rear wheels.
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: 4 motion
« Reply #10 on: December 10, 2010, 05:52:37 pm »
You're  wrong. The front wheels are driven all the time. The most the Haldex can transmit to the rear wheels is 50% or, to put it another way, equal power/torque to the front wheels.
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: 4 motion
« Reply #11 on: December 12, 2010, 06:44:49 pm »
I never said the front wheels were undriven, its only the rears I have ever stated would be undriven.  And the information I have read suggested thats its capable of transferring up to 100% " A Haldex Traction LSC unit may divert up to a maximum 100% of the torque to the rear axle as conditions warrant. " this is off of wiki so there is a potential for it to be wrong but the potential for it too and what VAG code software to do can be very different things.
Offline Janner_Sy
  • -Receive: 113
Re: 4 motion
« Reply #12 on: December 12, 2010, 09:57:27 pm »
so is 4motion the same as haldex then?
Offline simonp
  • -Receive: 38
Re: 4 motion
« Reply #13 on: December 12, 2010, 10:01:51 pm »
100% to my mind implies that the R32 can be at times rear wheel drive and that cannot happen. The drive can be no more than a 50/50 split. The LSC can put all available power to the rear wheels, but the fronts will have an identical amount still going to them as well, hence 50/50.
Only the XWD system that Saab uses can transfer 100% of the torque to the rear wheels. I believe it can even do it to just one wheel in the unlikely scenario that the other 3 were on ice.
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: 4 motion
« Reply #14 on: December 13, 2010, 09:12:48 am »
Ok well we are talking about a wording issue here then.  Looks like the XWD system is also a Haldex but Gen 4.  Does anyone know which system they have fitted in the MK6 R?
