Author Topic: GPS Antenna - Where have you got yours?  (Read 11137 times)
Offline Rob GTI
Re: GPS Antenna - Where have you got yours?
« Reply #15 on: December 15, 2010, 02:26:35 pm »
That makes sense. Maybe I'll have to go to the extreme of putting my antenna on the outside of the car as well  :rolleye:
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline mortygttdi
  • -Receive: 146
« Reply #16 on: December 15, 2010, 04:58:35 pm »
Rob you could try and place the antenna in the top of the screen or if you don't like the thought of looking at the little square puk then take the wire to the rear of the car and place it in the top corner of the rear screen??
If its got a direct view of the sats then it should be better than something between the puk and the sats.
Darren
Offline apollo13
  • -Receive: 47
« Reply #17 on: December 15, 2010, 05:06:35 pm »
In my work van that has factory fitted sat nav the gps antenna is stuck inside the windscreen above the rear view mirror (not sure why Iv got a rear view mirror as I can't see out the back!!).
When i had the screen replaced due to a stray scaffold pole the guy who replaced it said the screen was a special heat reflective type and the gps has to go in that particular place because that part of the screen is not coated and therefore would'nt interfere with the signal.
Do the early GTI's have heat reflective screens?
Oh and my gps antenna in the golf is just under the top tray and I get 10/11 out of 12  :happy2:
« Last Edit: December 16, 2010, 05:13:13 pm by apollo13 »
