Author Topic: Seized nipple  (Read 1522 times)
  • -Receive: 291
Seized nipple
« on: December 14, 2010, 12:43:52 am »
Took the car in for its 3rd year T&D service plus first MOT.
One of the bleed nipples on the front brake caliper had seized. Rather than risk causing damage and leaving me stranded in Stratford, Listers have asked me to bring the car back in a week's time (problems with work for me) to rebleed as they will make sure the caliper is there at the garage.
My questions:
Is it normal to have seized caliper nipples? If not, what could have caused it? VW Solihull at one point had to replace the rear ABS sensor - I presume this has nothing to do with it?
What are the chances of them actually breaking the caliper if they try too hard?
cheers
stealth
Offline edd666999
  • -Receive: 89
Re: Seized nipple
« Reply #1 on: December 14, 2010, 01:16:01 am »
 :signLOL: you said nipple.
the worse they can do i assume is thread it...in which case its their fault and they replace the caliper.
Offline vRSAlex
  • -Receive: 253
Re: Seized nipple
« Reply #2 on: December 14, 2010, 06:30:08 am »
Not massivly common, but I do see it from time to time.  I usually use a 6 sided socket to slacken the nipples off rather than a multipoint spanner.  It might not be seized, but just tight.  As the nipples are hollow they can just snap then the part left in the caliper would need drilling out.
Its no ones fault, just unlucky.
Follow AKS tuning on Facebook
Offline humkar
Re: Seized nipple
« Reply #3 on: December 16, 2010, 12:04:24 pm »
I never knew cars had nipples. I guess I've learned something new today.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Seized nipple
« Reply #4 on: December 16, 2010, 12:34:10 pm »
 :xmassmiley:
« Last Edit: December 16, 2010, 12:39:42 pm by danishmkvgti »
Over the top mod list ;o)
