Author Topic: Possible stupidity on the way  (Read 2948 times)
Offline johnboy07
« on: December 14, 2010, 08:30:01 pm »
Im contemplating doing the clutch change on my golf. Am i being a tad stupid. On previous cars i have done almost everything. Im not worried about undertaking the work and hopeing to save myself some money. Apart from stripping the car, removing driveshafts ect Are there any other bits i should be aware of.
Will the clutch need adjusting. do i need vcds for anything.
Also does the gearbox come away without dropping an engine mount to lower that side to slide the gearbox off the locators.
Or should i stop being tight and pay a garage.
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
Offline edd666999
  • -Receive: 89
Re: Possible stupidity on the way
« Reply #1 on: December 14, 2010, 08:33:01 pm »
doooo it   :notworthy: :notworthy:
**im fully aware this doesnt help
Offline PDT
  • -Receive: 142
« Reply #2 on: December 14, 2010, 08:36:11 pm »
I find the mk5 platform harder to work on than most other cars with gearbox related work.
Offline TrickGTI
« Reply #3 on: December 14, 2010, 08:38:32 pm »
If Youv got a pretty good mechanical mind then go for it no vag com or adjusting needed as it's hydraulic  :smiley:
2006 Tornado red GTI
Offline Aaron_RJ
« Reply #4 on: December 14, 2010, 08:39:27 pm »
is fine todo you will need to remove n/s gearbox mount and an extra pair of hands to help remove gearbox
2007 GTI | 18'' Monzas |Xenons|Highline|MFSW|Lux pack| Factory Tints |Cruise control
Mods: VWR Quickshift |Forge DV |Autotech HPFP| Sportlines | |Goodrich hoses |Milltek non res TBE | Stage 2 map | Custom CAI
Offline johnboy07
« Reply #5 on: December 14, 2010, 08:43:16 pm »
ooo lovely. i may even take some photos to help people if there also feel crazy in the future. Just cant justify paying someone else if i could probably do it myself. Also i have a few mechanics as friends, which i could ask for help if i get stuck.
Will wait for a while though as my clutch hasnt slipped for a while now. weirdly it slipped at stage one and now im stage 2+ it hasnt.
think i will be buying a haynes manual just in case
Offline damoegan
« Reply #6 on: December 14, 2010, 08:45:04 pm »
I will be doing the same thing once I save for a new clutch...
Offline damoegan
« Reply #7 on: December 14, 2010, 08:47:17 pm »
Dave, have you ever done a box/clutch change on a mk4 Ibiza Cupra? Feck its tight, box needs to come out at a stupid angle. Even with a engine mount off its very tight....
Offline PDT
  • -Receive: 142
« Reply #8 on: December 14, 2010, 09:08:09 pm »
Same with most modern cars tbh, have done a few ibiza tdi's which arent too bad.
Offline humkar
« Reply #9 on: December 14, 2010, 10:36:32 pm »
Yeh go for it! You'll be in a better position to know if it's doable once you're doing it.  Lol   :grin:
Best of luck to you.
« Reply #10 on: December 14, 2010, 10:42:56 pm »
The guys at vwr must have it down to a fine art as I have seen them take a box it pretty quick. Done a few in my time but always had to loosen up the engine mounts just gives you that little bit room/give you need
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #11 on: December 15, 2010, 10:31:56 am »
fcuk that!!
Offline johnboy07
« Reply #12 on: December 15, 2010, 09:11:19 pm »
lol not something you would attempt the joe.
Is a little crazy but most things on cars are simple enough with the right tools and some know how. seem confident now. we shall soon see how much of a good idea this is.
Offline gazbutS3
« Reply #13 on: December 15, 2010, 09:17:03 pm »
I would do my own clutch if I had a ramp/4 poster, its not something I would do on my back on the drive on axle stands
h4rdy
« Reply #14 on: December 15, 2010, 09:20:03 pm »
Same as no problem but not on the drive in the snow!
