Author Topic: "Mirror down" function  (Read 5527 times)
Offline Simebaby
« on: February 21, 2009, 04:41:46 pm »
Hi All
Trying to figure if my Mk5 is broken... I was having a look at the options via the highline, and I noticed that the "mirror down" function was turned off. I guessed this would tilt down the mirror when in reverse.
I set the mirror switch to the left (passenger) mirror, and indeed when selecting reverse (it's a DSG), the mirror drops down. However, when I select drive and move off, the mirror stays pointing down unless I move the mirror switch away from the left position. I'm guessing this isn't how it's supposed to work (I would expect the mirror to return to the normal position when leaving reverse gear) - am i wrong, or does it need a reset / fixing?
TIA
Si
Offline WhiteGTI
  • F-A-S-T
Re: "Mirror down" function
« Reply #1 on: February 21, 2009, 04:49:05 pm »
Your correct, when you go out of reverse gear it should angle back upwards again. With mine, it does not do it immediately, I have to drive over a certain speed (maybe 10mph), and then it will return to the upright position.
2006 E46 BMW M3 - 343hp
Offline Shaun
« Reply #2 on: February 21, 2009, 05:40:44 pm »
You do have move forwards subsequently at about 10-15mph before the mirror moves back to the 'normal' position.
Keep The Faith
GTI Edition 30 No. 0687 - Candy White - 5 Door - Lux Pack 1 - Park Sensors - ITG Filter - Bluefin - ECD Insert - Cruise Control
Previously: Mk1 Golf - Mk1 Jetta - Mk1 Polo Coupe - Mk2 Jetta - Mk3 Golf - Mk4 Passat - Mk1 Polo - Bora - Audi A4 / A6 / A8 - Mk3 Polo - Mk4 Golf
Offline Simebaby
« Reply #3 on: February 21, 2009, 05:53:41 pm »
Cheers all - indeed you're right. I didn't go fast enough before, so thought it was broken.  :smiley:
Offline hotrod30
« Reply #4 on: February 21, 2009, 06:15:41 pm »
I thought exactly the same thing when I first got mine. Great feature, I can park very accurately on the passenger side... shame it’s not an option on the drivers side.
Candy Edition 30 (1783)
Offline smithen999
« Reply #5 on: February 21, 2009, 09:23:31 pm »
is this a function that is only available with h/line?
i had this function on my old 330 and miss it!
Offline Makaveli
« Reply #6 on: February 21, 2009, 09:42:50 pm »
Also is this not only available on the 2007 onwards models?
I thought I read that somewhere?
« Reply #7 on: February 21, 2009, 10:00:04 pm »
You need to have the optional rear parking sensors or the lux pack for the tilting passenger mirror functionality.  :smiley:
Offline smithen999
« Reply #8 on: February 22, 2009, 10:44:13 am »
cheers for that, I wont be having this function then!
Offline Moschops
  • -Given: 118
  • Edition 30 No 2275
« Reply #9 on: February 22, 2009, 01:30:01 pm »
Ah ha...I also thought this...question answered, cheers fella's :happy2:
Cheers,
Wayne
Offline golfman
  • -Given: 17
« Reply #10 on: February 22, 2009, 05:37:02 pm »
I take it this cant be retro fitted?
Vag-com Hex+Can in scotland
I Hate Timewasters...
Offline 182_blue
  • -Receive: 54
« Reply #11 on: February 22, 2009, 06:00:10 pm »
anything can be retro fitted if you have the money and time, oh and maybe skill too  :laugh:
« Reply #12 on: February 22, 2009, 06:04:21 pm »
yep, true. there will probably be a control module needed, for parking sensors. if you fit factory parking sensors, its possible it would work, because you have the sensor installed for the car to know its in reverse. this is when the mirror will go down
Offline golfman
  • -Given: 17
« Reply #13 on: February 22, 2009, 06:45:43 pm »
I dont have factory fit parking sensors,got them done @ my local dealers,so the answer will probably be no :sad:
Offline 182_blue
  • -Receive: 54
« Reply #14 on: February 22, 2009, 06:56:43 pm »
im not sure you need parking sensors for this option, as i thought it was standard on early Gti's ?
