June 27, 2024, 10:02:35 pm
All Things Mk5
Cosmetic/Interior Modifications
Rear wheel rubbing
Topic: Rear wheel rubbing (Read 1743 times)
coullstar
Always Involved
-Given: 0
-Receive: 1
Rear wheel rubbing
December 16, 2010, 10:27:32 pm »
Ok it looks like Im going to struggle to sell my wheels so I may as well try them on. After thinking about options for the front Im now thinking about the rear. Has anyone ever encountered rubbing on the rear and what was it that was rubbing?
The reason Im asking is that I will be using the car to tow my motorbike + trailer and with all the gear in the back it can compress the suspension quite a bit so Im a little worried about rubbing. Not bothered too much if its liner etc I just dont want the outer arch to be damaged.
Last Edit: December 16, 2010, 10:35:20 pm by coullstar
Top Cat
Top cat
Just look at my post count
-Given: 171
-Receive: 335
Almost Jacamo
Re: Rear wheel rubbing
Reply #1 on:
December 16, 2010, 10:30:51 pm »
You need to give us a clue on the spec of the wheel what is the width and offset.
coullstar
Always Involved
-Given: 0
-Receive: 1
Reply #2 on:
December 16, 2010, 10:37:18 pm »
Of course, 8.5x18, ET42. Have a set of 225/40 Goodyear F1's to fit. Might go for 215's. The cars never going to be on track, just daily use.
Top Cat
Top cat
-Given: 171
-Receive: 335
Almost Jacamo
Reply #3 on:
December 16, 2010, 10:41:55 pm »
I have same size nearly, 45 offset on mine and get slight rubbing on the driver's side for some reason though mine is pretty low, though i have 235 PS2 on. 215 will solve your problems, just dont rag it round bends as i have heard of tires pulling of the rim at that size with that spec wheel.
coullstar
Always Involved
-Given: 0
-Receive: 1
Reply #4 on:
December 16, 2010, 10:53:40 pm »
That may be a problem then as I when I say daily driver I dont exactly drive like miss daisy
. What was rubbing though on the car? Was it the outer arch?
Top Cat
Top cat
-Given: 171
-Receive: 335
Almost Jacamo
Reply #5 on:
December 16, 2010, 11:00:58 pm »
Aye on the outer edge, you cant even roll them as there is fook all there to roll.
All Things Mk5
Rear wheel rubbing
