Author Topic: loss of power at 4000rpm with revo stage 2  (Read 5843 times)
Re: loss of power at 4000rpm with revo stage 2
« Reply #15 on: January 05, 2011, 01:11:48 pm »
When you say changed the fuel pump, do you mean an uprated one such as APR or Autotech or just the standard OEM HPFP?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #16 on: January 05, 2011, 01:59:13 pm »
As has been said you can't just run other people's settings without logging.
It is known for people to get fuel cuts on Stage 2 (i did and i know of a couple of others who have)
Ideally you need to log the car so you can see what is happening when the issue occurs.
It sounds like it is the pump but logging would give a better idea.
If you can find someone nearby with VCDS then log blocks 115 (Boost Specified & Actual) 114 (N75 Duty Cycle) and 230 (Fuel Rail pressure Specified and Actual). Also do another log on blocks 115, 114 and 020 (Cylinder Timing). Make sure turbo mode is activated (the VCDS owner should know what i mean)
When you log find a empty stretch of road or a private road. Ideally do the log in 3rd or 4th gear. Start at 2000rpm and floor the car to 6000 rpm (no need to go higher and i am NOT instructing you to speed on a public road). This puts the car under a consistent load and will help identify any problem areas.
If you don't know what to look at with the logs PM me and i'll give you my email and have a look at them. Or if you know how post them up on here.
This will help rule out the issue being the pump and also if it is timing pull. T5 should be fine but you may aswell check.
« Last Edit: January 05, 2011, 02:00:48 pm by vRS Carl »
Offline chedone
« Reply #17 on: February 22, 2011, 01:35:21 pm »
all fixed thanks to the phirm
ended up being the injectors so had all the valves cleaned as they were all coked up while the inlet was off.
car runs sweet now
first class down at THE PHIRM !!!!  thanks guys
Ched
« Reply #18 on: February 22, 2011, 03:03:53 pm »
car runs sweet now
....Glad to hear all running sweet again  :happy2:
Are you thinking of now having a catch tank system re your valves?
« Last Edit: February 22, 2011, 03:05:25 pm by RedRobin »
Offline chedone
« Reply #19 on: February 22, 2011, 09:15:17 pm »
yeah i just put the BSH revamp kit on but was thinking of the catch tank or the guys at the phirm said about water injection..
not to sure at the moment looking in to it as it was really bad. what are you running
Ched
« Reply #20 on: February 23, 2011, 12:12:04 am »
I'm now running the Forge catch tank system. I was running the BSH but although functional there were things I didn't like about it.
Forge review:   http://www.mk5golfgti.co.uk/forum/index.php/topic,16343.0.html
