September 21, 2024, 09:29:54 am
All Things Mk5
Mk5 General Area
Cam Belt
Topic: Cam Belt (Read 980 times)
RustyGTI
Cam Belt
December 17, 2010, 10:41:52 pm »
Hi all
When starting my gti from cold the cambelt makes a squeaking / chirping noise. VW Wepstbury said it was a noisy cambelt. They put some 'powder' on it which worked for a bit but its still doing it from cold. Anyone else had this problem?
Russ
edd666999
Just look at my post count
-Given: 24
-Receive: 89
Re: Cam Belt
Reply #1 on:
December 17, 2010, 10:49:13 pm »
do a search because i have read about this before, it got fixed under warranty
Russ_leeds
Won't Shut up.
-Given: 24
-Receive: 16
Re: Cam Belt
Reply #2 on:
December 17, 2010, 11:19:13 pm »
yeah i had this last year. had it changed under warranty
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Kalpsn2000
-Given: 10
-Receive: 56
Re: Cam Belt
Reply #3 on:
December 18, 2010, 12:47:09 am »
Yes sounds like the cambelt and tensioner need replacing.
The previous owner of my GTI had this done due to the noise at cold starts (under extended warranty).
scooba
Won't Shut up.
-Given: 18
-Receive: 17
Re: Cam Belt
Reply #4 on:
December 18, 2010, 07:46:55 am »
As above , sounds like the cam belt tensioner , I think warranty will sort this for you the cost off belt and tensioner and labour but I am sure you will be advised to replace the water pump as a precautionary and they cost around £30 iirc .
All Things Mk5
Mk5 General Area
Cam Belt
