Author Topic: Stage 2 Revo & Exhaust  (Read 1361 times)
Offline edition_30
« on: December 18, 2010, 03:51:05 pm »
I’m currently running stage 1 revo on my Ed & am considering purchasing a full tbe milltek. Now amd who will be fitting the exhaust have mentioned that i will need to upgrade my software to stage 2. I’m sure i remember people mentioning on her that when they went stage 2 they needed to upgrade the fuel pump as the standard pump could not cope, is this case?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Stage 2 Revo & Exhaust
« Reply #1 on: December 18, 2010, 03:56:34 pm »
No that is only Stage 2+.
Stage 2 only request 110bar fuel pressure and the OEM pump can cope up till 115bar.
Stage 2+ requests 130bar which is why you need the pump upgrade.
EDIT: just realised you have a K04 ED30 so what i have just said may not be true. It is for K03s cars and i'm pretty sure it is for K04 but someone with a K04 may be able to clarify better.
« Last Edit: December 18, 2010, 03:58:08 pm by vRS Carl »
« Reply #2 on: December 18, 2010, 03:58:20 pm »
You may get a CEL if you run the tbe with stage 1.
Stage 2 is mapped to not give the cel and maximise the extra performance of the tbe. You only need the uprated hpfp for stage 2+.
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: December 18, 2010, 04:12:36 pm »
all the above is correct.
Bear in mind though that you dont need the full TBE to go stage 2.  you could just get the downpipe, saving yourself £500.  that way you can put your saved money towards a fuel pump and stage 2+ instead.
Offline PDT
  • -Receive: 142
« Reply #4 on: December 18, 2010, 07:34:34 pm »
However keep in mind that even on stage 1 theres big gains with an uprated hpfp. Stage 2 with REVO often requires quite conservative settings to avoid fuel cuts without an uprated HPFP.
Offline edition_30
« Reply #5 on: December 20, 2010, 11:19:34 am »
This is what i am worried about, do you think the revo dealer would bear this in mind when mapping stage 2 & set thecorrect settings to avoid the fuel cuts?
Offline Janner_Sy
  • -Receive: 113
« Reply #6 on: December 20, 2010, 03:52:38 pm »
Id like to think so.  They wouldnt have such a good reputation if they didnt.
