Author Topic: RNS310?  (Read 15802 times)
Offline J400uk
  • -Receive: 27
Re: RNS310?
« Reply #15 on: April 19, 2015, 10:10:49 pm »
I would go for RNS 315, Similar unit but some units have build in DAB and Bluetooth
I've got that in my MK6, but in the MK5 it won't support the Highline display so you're better of with the RNS 310.
im keen to put one in my gt tdi, as a newbie forgive my silly questions but what would i need to buy to do the job?
Mainly just the GPS antenna and adaptor for the radio antenna connector, if I remember right its otherwise a straight swap.
Offline Phil_H
Re: RNS310?
« Reply #16 on: April 21, 2015, 08:08:05 pm »
I have an RNS315 in my MkV, correct with not supporting the Highline display, but still a very nice OEM stereo, I've also got a built in Mic fitted (in the correct place behind the interior light unit), the Blue Tooth works faultlessly with my iPhone :)
Oh...and DAB ;)
Offline cookmort
Re: RNS310?
« Reply #17 on: April 22, 2015, 06:21:37 pm »
Is the Bluetooth built into the unit? Don't think my car has a mic or Bluetooth in it at the moment.
Offline Phil_H
Re: RNS310?
« Reply #18 on: April 24, 2015, 10:40:14 pm »
Yeah bluetooth is built in (Rev R ones didn't have BT I think), and not all are DAB
I had an OEM Mic fitted about the same time as the stereo, routed behind dash, up the A pillar and under the headlining etc... There is a proper slot for it in the interior light panel.
Offline J400uk
  • -Receive: 27
Re: RNS310?
« Reply #19 on: April 25, 2015, 06:16:24 pm »
Just to add to the above, I found this list of models helpful when shopping for an RNS 315 - http://www.briskoda.net/forums/topic/287901-amundsen-bluetooth/?p=3421360
Offline Phil_H
Re: RNS310?
« Reply #20 on: April 25, 2015, 08:02:28 pm »
Thats the list that helped me get my DAB & BT one for £175 off a badly written eBay advert :)
Offline cookmort
Re: RNS310?
« Reply #21 on: May 04, 2015, 12:02:30 pm »
I've found a 315 that I'm planning on buyin, it has the Bluetooth and dab built in. How do I connect a microphone for get phone? I don't think my car has it in already!  Can I wire one to the unit or has it got one built in?
Offline J400uk
  • -Receive: 27
Re: RNS310?
« Reply #22 on: May 04, 2015, 02:23:00 pm »
You'll need to wire the Mic directly to the unit, it doesn't have one built in. I'm sure I've seen some instructions floating about online if you do a search and if I remember right Kufatec sell the loom required.
Offline cookmort
Re: RNS310?
« Reply #23 on: May 05, 2015, 07:18:51 pm »
Thanks dude. They have the cable I need :)
Do I need to get it coded to the car? Kufatec suggested that I will do.
Is could you lovely people recommend anyone local to South Yorkshire that could do it and not charge dealer prices?
