Author Topic: improving aerodynamics with OEM parts  (Read 140228 times)
Re: improving aerodynamics with OEM parts
« Reply #90 on: March 03, 2011, 09:40:55 pm »
Cheers  :drinking:
The actual weights aren't too important if the all materials are very light. I was thinking that they might be heavier than the materials you mention - It looks like quite a lot in the photo.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #91 on: March 03, 2011, 09:43:24 pm »
I have the parts right here and the would need some sort of weightsaving elsewhere to be compensated for RR. CF for example  :jumping:  :booty:
Over the top mod list ;o)
Offline Snoopy
  • -Given: 31
« Reply #92 on: March 03, 2011, 09:49:57 pm »
Robin it weight is next to nothing. I have removed similar parts on other VW cars including a mk6 TDI and theres not a much difference between whats there on a GTI and whats new. It looks alot bigger in the photos compared when you see them underneath. Its a mk5 anyway so a heavy car and a couple of Lbs makes little difference down there. I will simply goto the toilet and deposit the difference before i go for a critical drive  :P
I just come back from Audi dealer!!
Ordered:
A3 3.2 undertray  1K0 825 237 P
Tank deflector 1K0 501 713 D
Rear muffler deflector 1K0 825 206 A
And all the necessary screws, at least I think.
This is what i ordered just not had time to go pick it up from a mate who collected it for me.
Engine undertray
1K0 825 237 P     Noise Insulation £28.84
1K0 825 951        Hex headed bolt (Combi) 89p (need 3 according to above list)
Rear axle cover as fitted to bluemotion
1K0 501 713 D    Trim for Rear Axle £26.73
1K0 501 682        Retaining bracket £1.89
N 905 483 05      Not on Stamm
N 901 838 02      Not on Stamm
Rear covers from A3 or TT
1K0 511 539 E   Stone chip Guard £5.37
1K0 511 540 C   Stone Chip Guard £6.75
8E0 825 267      a spreader rivet £0.12 (need 4 so x4)
« Last Edit: March 03, 2011, 09:55:54 pm by Snoopy »
« Reply #93 on: March 03, 2011, 09:53:42 pm »
....You weren't thinking of CF wings by any chance were you, Jake?  :laugh:
« Reply #94 on: March 03, 2011, 09:55:44 pm »
Engine undertray
....Not for me!!
Offline Snoopy
  • -Given: 31
« Reply #95 on: March 03, 2011, 09:59:03 pm »
Engine undertray
....Not for me!!
Thats just the name in ETKA for the undertray. I don't like the way the sump is open to the eliments and so corrosion. I have a VW sump on a 6 year old car to replace this coming weekend partly imo because its had the open undertray and has suffered with weather so rotted. My GTI has a screwed on sensor right on the bottom of the sump last thing i want is having to replace it as well as the sump in coming years. The undertray will help keep the engine bay area more free from salt etc.
« Last Edit: March 03, 2011, 10:00:48 pm by Snoopy »
« Reply #96 on: March 03, 2011, 10:05:19 pm »
Engine undertray
....Not for me!!
....sh*t!! I think you've just sold me on getting just this undertray (and the 3 fixing bolts - only 3?)
Offline Snoopy
  • -Given: 31
« Reply #97 on: March 03, 2011, 10:15:46 pm »
Just 3 extra bolts as it uses the other 8  of the standard undertray.
« Reply #98 on: March 03, 2011, 10:23:35 pm »
I don't know why I've just clicked you a Thank You, Geoff - You just cost me another 30 squid!
Offline Snoopy
  • -Given: 31
« Reply #99 on: March 03, 2011, 10:51:15 pm »
The mk5 GTI maybe fine, i don't know without looking under some of them on how there doing but a 1.4 16V we have owned from new is suffered and has a slight weep from the bottom of the sump.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #100 on: March 03, 2011, 11:46:49 pm »
So that's why we own a Mk.V/EA113 with a cast aluminium sump and no
cheap Mk.VI/EA888 with the poor steel one !!
 :grin:
"You get what you pay for."
Offline Snoopy
  • -Given: 31
« Reply #101 on: March 04, 2011, 09:15:39 pm »
So that's why we own a Mk.V/EA113 with a cast aluminium sump (with doddy belt tensioner, expensive belt changes, rusty wheel arches and sills) and no
 :grin:
Corrected for you  :P
« Last Edit: March 04, 2011, 09:19:38 pm by Snoopy »
« Reply #102 on: March 04, 2011, 09:20:10 pm »
Does the extra undertray reduce the ground clearance by much? It's a bit critical on my car's setup.
  • -Given: 243
  • -Receive: 154
« Reply #103 on: March 04, 2011, 09:23:00 pm »
Nope, it just follows the lines of the old one  :happy2:
Offline Snoopy
  • -Given: 31
« Reply #104 on: March 04, 2011, 09:25:06 pm »
I was just about to say similar, you can see it on page one and looking under a TDI today at work its the same lines just covers back to the subframe.
