Author Topic: improving aerodynamics with OEM parts  (Read 140008 times)
Offline coullstar
Re: improved aerodynamics with OEM parts
« Reply #15 on: December 30, 2010, 04:50:28 pm »
Very intelligent modifications.
That brace will do nowt, Robin. Unless they can prove me wrong..
and me, looks pointless.  It seems to narrow to add any noticable chassis stiffness and the holes in it will nowt.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #16 on: January 01, 2011, 12:43:33 pm »
Do You know these braces?
"You get what you pay for."
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #17 on: January 01, 2011, 03:42:35 pm »
There's only enough space for it when there's no center exhaust or if you have a
very small c.e. like ATP or Supersprint:
(number 3 in the picture)
1K0 825 206 A - Unterbodenverkleidung links hinten
N 909 707 02 - Schnappmutter 2 x
WHT 000 713 - Sechskantbundmutter (2 x ??)
1K0 825 221 - Winkel
N 905 483 03 - Sechskantbundschraube M8
N 901 838 02- Sechskantbundmutter selbstsichernd
N 908 338 01 - Spreizmutter
« Reply #18 on: January 01, 2011, 03:47:56 pm »
....I don't know any of these braces. The consensus of opinion here seems to be that the Mk5 Golf chassis doesn't need stiffening braces. Obviously there wouldn't appear to be any aerodynamic improvements. I don't know enough to have formed an opinion yet.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #19 on: January 01, 2011, 03:49:13 pm »
2a and 2b and 4, do you have partnumbers fo these and accesories??  thx  :happy2:
Over the top mod list ;o)
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #20 on: January 01, 2011, 07:08:29 pm »
"4" is "Verkleidung Hinterachse" = "Hinterachsverkleidung" = rear axle cover:
Easy and quick to install !!
Part numbers for 2a and 2b will come soon, these are OEM-parts from Audi TT and A3.
Attention, all these parts at the rear do fit fwd cars only !!
@ Robin:
I know that the Golf V doesn't need additional braces. But when I saw the braces
on page 1 I'd too show You these.
 :drinking:
« Last Edit: January 01, 2011, 08:49:01 pm by the bruce »
Offline gillm
« Reply #21 on: January 01, 2011, 07:15:32 pm »
me too , looks like the only thing it will do is lighten your pocket , mk5 is stiff enough for road use which 99.9% of car on here do . also "my thoughts only" if you have a mk5 really stiff on the back defeats the point of indapendant rear corners
west tuned gt28 @ 340hp
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #22 on: January 01, 2011, 07:21:51 pm »
I guess we all agree to this.  :wink:
2a & 2b:
left side:  1K0 511 539 E 5,12 €
right side: 1K0 511 540 C 5,30 €
8E0 825 267 0,44 €  4 x
Pease note: little bit tricky to fit !!
« Last Edit: January 01, 2011, 08:48:12 pm by the bruce »
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #23 on: January 10, 2011, 08:18:21 pm »
Really interesting stuff here. I wonder if they make any difference to fuel consumption?
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #24 on: January 10, 2011, 11:45:33 pm »
a very small amount at highway speed  :wink:
Most parts are factory fitted to the eco Golf TDI blue motion, so they should make a difference.
My main motivation was reducing aerodynamic lift at the rear (~ 35 kg @ 200 km/h) for better
stability when high speed cornering. I don't like huge wings, so I went for invisible parts.
« Reply #25 on: January 11, 2011, 12:49:10 pm »
....Invisible wings, huh? But will they make your baby fly?  :evilgrin:
Btw, we don't get much opportunity to enjoy autobahn high speeds in the UK  :sad1:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #26 on: January 11, 2011, 01:07:36 pm »
I'd try these one underneath my car. Any tipps for fitting them at the right place?  :signLOL:
 :congrats:  As you see - wings add safety !!  :happy2:
Perhabs you have more race tracks in the UK. And high speed on autobahn becomes boring in the long run.
Safety and noise emission regulations make it hard to in germany to converse former airbases to race tracks.
Offline cmdrfire
    • Commander Fire - my blog
« Reply #27 on: January 14, 2011, 06:41:49 pm »
Does anyone know if the 'golf ball' pattern actually makes a difference?
The dimples do make an improvement aerodynamically, primarily by inducing a lowering of the drag coefficient by improving the Reynold's number:
As a note, maybe 10-15% of an "eco" car's efficiency gains are from improved aerodynamics on the underside.
Remember though that increases in aerodynamic downforce also result in increases in drag, making the vehicle less efficient and and reducing vmax.
I saw a few years ago on one of the American forums someone had fitted an undertray and a crude diffuser which he said improved high-speed stability; something which is entirely plausible, but which lacked any form of quantiative testing.
Undertrays designed to reduce drag will not, in my opinion, improve high-speed stability.
« Reply #28 on: January 14, 2011, 06:54:58 pm »
Still pissing excellence I see, Neo!
Now stop all that and get on progressing the LED tails project  :laugh:  :evilgrin:  :wink: [I got your txt -Ta]
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #29 on: January 14, 2011, 09:57:55 pm »
Thanks for the pic.  :happy2:
Yes, but we talk about reducing our Golfs' lift. There's no chance for real downforce.  :wink:
These undertray parts reduce turbulences and these tubulences cause both - drag and lift.
A smoother undertray helps getting a laminar air stream. The smoother, the faster the air
will pass the car's underbottom. The faster the air, the less drag and lift.
Just advantages, no problems. Just my 2 cents.  :happy2:
