Author Topic: improving aerodynamics with OEM parts  (Read 140295 times)
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: improving aerodynamics with OEM parts
« Reply #225 on: September 21, 2011, 03:39:06 pm »
ha ha, yeah it is nice unfortunately I didnt get to stop although fancied a spot of canoeing in the tarn valley which i guess is what you were doing?  The only pic I have is of the Aire at Milau but the geology is rather interesting even just seen from the car (several table top mountains and big valleys and gorges).
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #226 on: September 21, 2011, 06:49:44 pm »
looks nice !!  :driver:
"You get what you pay for."
Offline mortygttdi
  • -Receive: 146
« Reply #227 on: October 31, 2011, 12:59:08 am »
Just a note regards the 2 longer side trims that come standard on the golfs ie the ones under the sills, I had to order both sides has after 3 years with coilovers it took its toll and they where destroyed :evilgrin: any way the new ones are a superceded part and have bigger hump bits at the back similar to what it would be like with the 1a and 1b fitted but all in one.
I also have a new front undertray has I took it off some time ago and it went missing!! any way the car does seem much quieter at all speeds.
Darren
Offline mortygttdi
  • -Receive: 146
« Reply #228 on: October 31, 2011, 02:50:47 pm »
Got all the pieces on order but Audi had the TT parts in stock so the 2a and 2b are on the car,
I didn't realise until I was under the car that I have the silencer nr the rear axle due to having the GTI cat back :confused: I ordered no#3 on the list :confused:
Do I cancel them parts or try and fit them??? why dont I check before I buy things :fighting2:
Darren
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #229 on: October 31, 2011, 03:01:23 pm »
Darren
 :signLOL: I DO know the feeling  :signLOL:
Over the top mod list ;o)
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #230 on: October 31, 2011, 09:14:35 pm »
With the front silencer on I think you might struggle to fit part 3 or have to chop it away into a much smaller piece.
Offline mortygttdi
  • -Receive: 146
« Reply #232 on: November 01, 2011, 06:19:35 pm »
I fitted the tank guard but have had to cable tie it on on one side"no fixing nr the exhaust side" any way I'm obviously going to have to drill it but I found this part number on ETKA N 910 011 01 - Blind rivet stud? I think this is to be inserted in the drilled hole then using a rivet gun squash then you have the fixing you need??
Does the above sound about right?
Darren
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #233 on: November 01, 2011, 10:01:25 pm »
On my 2008 GTI I did not need it.
If your GTI is older try it with drilling and insert the rivet.
Offline mortygttdi
  • -Receive: 146
« Reply #234 on: November 02, 2011, 11:12:39 pm »
Cheers Bruce stud ordered @ VW should be here Friday,
Now to sort the timing out on this engine, any one know about how to change the timing on a bkd 16valve engine :happy2:
Darren
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #235 on: November 03, 2011, 12:54:13 am »
The Clio 197/200 has a very good and functional system that wouldn't be too far off a Golf's size. The 197's in particular is very cheap and easy to come by and testing has shown from 80mph upwards, it generates in the region of 40kgs of downforce. Compared to my old MK5, the Clio200 I had was glued to the track at high speed.
197
200
This looks serious !!  :happy2:
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #236 on: November 17, 2011, 11:14:25 am »
will the 1K0 825 237 P fit on my car with an AXX engine and DSG gearbox?
PLANS: Stage 2+
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #237 on: November 17, 2011, 02:04:21 pm »
Yes, it will.
''237 P'' fits all Mk.V/Mk.VI GTIs.
  • -Given: 243
  • -Receive: 154
« Reply #238 on: November 17, 2011, 02:05:57 pm »
Yes, it will.
And Touran 1T, as the wife's touran has one  :happy2:
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #239 on: November 17, 2011, 02:16:18 pm »
Yes, it will.
don't drive a Mk5 lol, 2006 8P
PLANS: Stage 2+
