Author Topic: improving aerodynamics with OEM parts  (Read 139373 times)
Offline Snoopy
  • -Given: 31
Re: improved aerodynamics with OEM parts
« Reply #30 on: January 15, 2011, 08:41:21 pm »
A very interesting thread.  :smiley:  :drinking:
After spending ages/money and many gallons on waxoyling my mk6 adding all these aero covers would just add to the protection. :happy2:
I was disapointed in the standard engine bay cover of the mk6.  :ashamed:
Apart from number (3) at the rear until i change the exhaust i think i can fit them all to my car?
The engine cover im not sure about from the photo as the mk6 has triangular bits that stick down at the sides screwed to the front bumper, that also support the inner front wheel arch covers and the engine undertray in place. Is the mk5 the same?
Does anyone have a full list of the parts needed for all these modification and some guide prices in the UK?
Thanks for a great thread that really interests me
Geoff. :smiley:
« Last Edit: January 15, 2011, 09:20:18 pm by Snoopy »
« Reply #31 on: January 15, 2011, 11:14:35 pm »
....Does this info bruce posted earlier in the thread help?:
^ Are these part #s common to UK?
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #32 on: January 15, 2011, 11:30:07 pm »
Hello Geoff,
yes, part #3 will fit only if there's a smaller center exhaust (like Eisenmann or Supersprint)
or no center exhaust (like TDI or the Scirocco R) or you have an non-resonated system.
The engine bay cover and all the other parts do fit the Mk.VI as well. I know Golf VI owners
that did this mod. And the pic with the numbers shows a Golf VI 2.0 TDI.
There are many parts. But just the larger parts front and rear in my list (that Robin posted)
are really easy to fit. So they're recommended.
"You get what you pay for."
Offline Snoopy
  • -Given: 31
« Reply #33 on: January 16, 2011, 09:15:52 am »
Thank you.  :drinking:
Are there any other covers i could also use under there that would add to protection ?
Complicated to fit is not a problem, i use to work in the motor trade and have full garage facilities (lifts etc) of my own.
« Last Edit: January 16, 2011, 09:21:49 am by Snoopy »
Offline Snoopy
  • -Given: 31
« Reply #34 on: January 16, 2011, 11:25:30 am »
Sorry to be such a pain. The sides of the new undertray to its sides looks like the bottoms of the inner wheel arches not connected to anything? Im guessing this is part way through fitting and its just lower as it looks that way and its not a different fitment? Its that long since i looked at the front of mine and been under too many other VAGproducts since to remember correctly :ashamed:
Just want to make sure before i contact TPS to order the parts. :smiley:
Quote
2a and 2b comes from Audi A3 and TT 8J (fwd only).
Nr.3 comes from TDI BlueMotion and is best to be used with an non-resonated exhaust.
Nr.4 is ''Hinterachsverkleidung'' from TDI Blue Motion.
1a and 1b, The mk6 has triangular bits there from the factory, im not sure of the mk5, are these to make them bigger or just add to the mk5?
« Last Edit: January 16, 2011, 11:32:50 am by Snoopy »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #35 on: January 16, 2011, 02:06:53 pm »
Front and sides the same (old) screws als OEM are used. No difference.
Quote
The Mk.5 has them as well. But 1a and 1b are larger and cover the smaller ones perfectly.
I don't know if they fit the Mk.6.
There are protectors for the lower wishbones as well. Never seen them on my own.
Offline Snoopy
  • -Given: 31
« Reply #36 on: January 16, 2011, 05:50:53 pm »
Thank you.  :smiley:
Engine undertray
1K0 825 237 P     Noise Insulation £28.84
1K0 825 951        Hex headed bolt (Combi) 89p (need 3 according to above list)
Rear axle cover as fitted to bluemotion
1K0 501 713 D    Trim for Rear Axle £26.73
1K0 501 682        Retaining bracket £1.89
N 905 483 05      Not on Stamm
N 901 838 02      Not on Stamm
Rear covers from A3 or TT
1K0 511 539 E   Stone chip Guard £5.37
1K0 511 540 C   Stone Chip Guard £6.75
8E0 825 267      a spreader rivet £0.12 (need 4 so x4)
« Last Edit: January 16, 2011, 08:34:26 pm by Snoopy »
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #37 on: January 16, 2011, 09:18:46 pm »
 :congrats:
Offline Aaron_RJ
« Reply #38 on: January 19, 2011, 06:28:30 pm »
fitted all my parts today will see if it makes a difference
2007 GTI | 18'' Monzas |Xenons|Highline|MFSW|Lux pack| Factory Tints |Cruise control
Mods: VWR Quickshift |Forge DV |Autotech HPFP| Sportlines | |Goodrich hoses |Milltek non res TBE | Stage 2 map | Custom CAI
Offline Poppa Dom
« Reply #39 on: January 19, 2011, 06:52:57 pm »
Be interested in your findings Aaron, considering doing this myself
« Reply #40 on: January 19, 2011, 06:56:48 pm »
How are you guys going to avoid the placebo effect and assess the difference? I may be wrong but aren't any differences going to feel very subtle and you would need a proper wind tunnel to know the facts?
Offline Aaron_RJ
« Reply #41 on: January 19, 2011, 07:10:27 pm »
your right robin just interested to see if it affects mpg
« Reply #42 on: January 19, 2011, 07:37:35 pm »
I'm not suggesting that they won't be of benefit though - Just tricky to accurately assess. Even accurate mpg without proper monitoring equipment might be unreliable due to so many everyday driving variables, imo.
Offline Aaron_RJ
« Reply #43 on: January 19, 2011, 08:55:41 pm »
Very true but I drive the same road at the same time with no traffic everyday will let you know tommorow
Offline cmdrfire
    • Commander Fire - my blog
« Reply #44 on: January 19, 2011, 10:20:06 pm »
Needs some CFD. Anyone got a laser scanner?
