Author Topic: improving aerodynamics with OEM parts  (Read 138950 times)
Offline Snoopy
  • -Given: 31
Re: improved aerodynamics with OEM parts
« Reply #45 on: January 21, 2011, 09:18:25 pm »
fitted all my parts today will see if it makes a difference
Have i listed all the parts i need? Or have i missed any? :smiley:
Offline Aaron_RJ
« Reply #46 on: January 22, 2011, 08:03:16 pm »
spot on mate  :happy2:
2007 GTI | 18'' Monzas |Xenons|Highline|MFSW|Lux pack| Factory Tints |Cruise control
Mods: VWR Quickshift |Forge DV |Autotech HPFP| Sportlines | |Goodrich hoses |Milltek non res TBE | Stage 2 map | Custom CAI
Offline Neimad
« Reply #47 on: February 01, 2011, 11:51:18 am »
Very true but I drive the same road at the same time with no traffic everyday will let you know tommorow
Any news on the repercussions of fitting these parts?
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #48 on: February 01, 2011, 12:24:44 pm »
Thank you.  :smiley:
Engine undertray
1K0 825 237 P     Noise Insulation £28.84
1K0 825 951        Hex headed bolt (Combi) 89p (need 3 according to above list)
Rear axle cover as fitted to bluemotion
1K0 501 713 D    Trim for Rear Axle £26.73
1K0 501 682        Retaining bracket £1.89
N 905 483 05      Not on Stamm
N 901 838 02      Not on Stamm
Rear covers from A3 or TT
1K0 511 539 E   Stone chip Guard £5.37
1K0 511 540 C   Stone Chip Guard £6.75
8E0 825 267      a spreader rivet £0.12 (need 4 so x4)
What does the rivet go into, that would worry me a bit! (just dont trust myself) and how easy would these parts be to fit on axle stands on a drive as I dont have the luxury of a ramp  :sad1:
Also any feedback Aaron?
Offline Snoopy
  • -Given: 31
« Reply #49 on: February 02, 2011, 01:39:57 pm »
Had mine on axle stands today for something else and to me it looks like the rivet fits in a hole on the arm thats easy accessable with the wheel off. :smiley:
Offline Aaron_RJ
« Reply #50 on: February 02, 2011, 06:47:12 pm »
Thank you.  :smiley:
Engine undertray
hi sorry for no reply oops
not noticed any difference in consupmtion easy enough to fit on axle stands , the rivets are plastic nd when rear stone guards are fitted the go through the guard and suspension arm and splay out
Offline Snoopy
  • -Given: 31
« Reply #51 on: February 02, 2011, 08:35:04 pm »
Anyone know what the two parts for the axle cover are that i could not find?
Offline Aaron_RJ
« Reply #52 on: February 02, 2011, 10:11:52 pm »
Is a fixing kit you dot need to use It though just use some self tapping bolts m8 thread
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #53 on: February 02, 2011, 10:45:02 pm »
I had the bolts from VW, but don't hesitate and use some standard ones.
Just take care it's zink plated or similar.
"You get what you pay for."
« Reply #54 on: February 02, 2011, 10:46:57 pm »
....I think stainless steel bolts would probably be best of all.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #55 on: February 02, 2011, 10:59:53 pm »
Of course, feel free to use stainless.
First I wrote ''stainless'', but I changed it for ''Zink plated or similar'' before clicking the button. :signLOL:
I try to avoid shiny bolts on, in and under the car (with the exception of exhaust).
« Reply #56 on: February 02, 2011, 11:08:22 pm »
....Any particular reason?
My thinking would be to achieve the best durability. Titanium might be rather expensive!
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #57 on: February 03, 2011, 09:08:17 am »
Not even at mototrway speeds?  hmm maybe there is somethign else about the GTI that affects the airflow like the front splitter making the air turbulent at the front removing the effectiveness of the smoother under-body....  :confused:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #58 on: February 03, 2011, 10:16:00 am »
The only reason is that I like to have it looking OEM where possible.  :wink:
Titanium bolts would be nice, not too expensive when standard M8 and no too hard
to get, but are there any benefits at this place?
We should save weight where it counts: at the front, so a carbon bonnet and placing
the battery in the rear will make a remarkable difference for example.
« Reply #59 on: February 03, 2011, 11:42:26 am »
....Well, I've got the carbon bonnet and might consider carbon wings but too much hassle to move the battery to the boot. Also, too much hassle to keep having to recharge a compact lightweight battery alternative.
You can see that my car is well beyond looking OEM although I do like to kid myself that it's kind of OEM Plus.
To be honest, so far I'm not convinced that the underside aerodynamic parts being discussed are of any real benefit at all apart from perhaps protection.
