Author Topic: Rear Wash / Wipe spray Jet  (Read 1529 times)
Offline Norbreck21a
« on: December 23, 2010, 02:27:25 pm »
A quick question that's been bothering me for some time. My rear wash/wipe jet is aimed too high and normally sprays over the roof (even when I'm travelling).
I've had a quick look and can't see anything to adjust ? Anyone know if it's even possible to adjust the spray direction ?
Andrew
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=l82kjklco30fsntflqjho31gaf&/topic,19740.0.html
Re: Rear Wash / Wipe spray Jet
« Reply #1 on: December 23, 2010, 02:57:32 pm »
IIRC... you can adjust it by sticking a pin in the nozzle and moving it!
**Going out to adjust mine!
« Reply #2 on: December 23, 2010, 03:03:42 pm »
^^ I was correct... you just need a needle or thin pin! Pull the cover off the hub (pulls on a hinge towards the drivers side) and stick the needle in the jet and adjust it!
« Last Edit: December 23, 2010, 03:06:33 pm by richwig83 »
Offline Norbreck21a
« Reply #3 on: December 23, 2010, 03:56:43 pm »
Thanks Rich,
Had a look at mine at lunchtime and swung the cover back as you suggested, and I was faced with a small black plastic pin sticking through the wiper arm retaining nut (which I guess is the spray nozzle) ? I shone at light at it and couldn't see a hole in the plastic pin to adjust anything. I'll have another go tomorrow.
Thanks for the heads up.  :happy2:
Andrew
« Reply #4 on: December 23, 2010, 04:14:35 pm »
Just cos im bored!  :signLOL:
  • -Receive: 291
« Reply #5 on: December 23, 2010, 06:01:14 pm »
You should aim the nozzle so the spray comes out at the 2 o'clock position - stops water ingress into the high brake light.
« Reply #6 on: December 23, 2010, 06:07:20 pm »
^^ Interesting....might try that!  :happy2:
Offline Norbreck21a
« Reply #7 on: December 23, 2010, 07:11:51 pm »
That explains that then chaps.
The little white adjuster ball in Rich's photo above is missing on my spray nozzle. No wonder it's going everywhere. Looks like a piece of ice may have forced it out ?
Wonder if the stealers keep these in stock, shouldn't be too much dosh ?
Andrew
« Reply #8 on: December 23, 2010, 07:45:02 pm »
^^^ ahh... yeah, that will explain it! I can find a MK4 part number but not a MK5... so i can only presume that they do that part separately!
