Author Topic: Airbag fault  (Read 46560 times)
Offline nads1_uk
Re: Airbag fault
« Reply #15 on: January 05, 2011, 02:22:02 pm »
Hi Fellas
  Finally got my car into a garage, they ran some check and found it could be 1 of 3 times so rather than trying lots of things that could become expensive, they've recommended taking it in a dealer for a diagnostics check does anyone know the rough cost of this?
Andy
  • -Receive: 291
Re: Airbag fault
« Reply #16 on: January 06, 2011, 08:54:45 am »
I think it's about £80.
Offline nads1_uk
Re: Airbag fault
« Reply #17 on: January 06, 2011, 10:45:04 am »
Cheers Stealth  :happy2:
Andy
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Airbag fault
« Reply #18 on: January 06, 2011, 10:48:19 am »
My car is in the garage for the same thing as i type.
Mine is the drivers side seat airbag and is having the igniter replaced.
The technician told me that sometimes in cold weather the gas in the igniter loses pressure. If you have ever used an outdoor gas cooker when it's freezing you will know what i mean. This then alters the reistance sensor in the igniter (saying it's not at the correct pressure to inflate if needed) and brings up a fault.
Knowing i have VCDS he told me to do the following:
Take the car on a drive with the heater on full and the heated seats on (if you have them) for a good 15-20 mins. Then stop and clear the fault. If it then comes back straight away the problem is likely to be wiring. If it clears check the car the next morning and if the light returns then it is probably the fault i described above.
Depending on wether your in warranty or not a wiring fix will be around the £100 mark. An igniter is around the £300-400 mark (depending on which one) for the part only. You would have labour on top of that. Luckily my car still has a warranty till July.
« Last Edit: January 06, 2011, 10:49:56 am by vRS Carl »
Offline nads1_uk
Re: Airbag fault
« Reply #19 on: January 06, 2011, 11:52:33 am »
Cheers for that VRS CARL
  When it was at my local garage they plugged something into the car, I assume this was VCDS and the fault was the drivers side crash sensor I believe.
  They reset the fault and I drove the car home without the fault coming back, about 2 hours later I had to move the car and the fault came back.  I rang them back and they suggested I take it to the dealers who hopefully would be able to find the fault easier.  My local garage didn't want to try several things until they found it and the labour costs would be high.
  This to me seems to be more than a wiring fault.
Andy
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Airbag fault
« Reply #20 on: January 06, 2011, 11:56:40 am »
If you can get the fault code off them you can put it in google to see what it is.
I would take it to a main dealer just because Local/indy garage fault code readers don't always give a code the dealer can understand. The dealer will just plug it into VAS and then follow the guided fault finding to correctly diagnose the problem.
Where are you located? If your near Salisbury i have VCDS and can scan it for you.
Offline nads1_uk
Re: Airbag fault
« Reply #21 on: January 06, 2011, 12:06:42 pm »
Cheers for the offer mate but I'm in north east  :sad1:
I've got the print  out from the machine, I'll see if its got a fault code
Thanks again
Andy
Offline nads1_uk
Re: Airbag fault
« Reply #22 on: January 06, 2011, 12:41:25 pm »
I've just found the print out;
Does anyone have any ideas??
Andy
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=4hqh5iba5j7udodhrjgc735pc5&/topic,19740.0.html
Re: Airbag fault
« Reply #23 on: January 06, 2011, 12:55:16 pm »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Airbag fault
« Reply #24 on: January 06, 2011, 12:56:20 pm »
That code has the following:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
01221 - Crash Sensor Side Airbag; Driver Side (G179): Faulty
01221 - Crash Sensor Side Airbag; Driver Side (G179): Open Circuit / Short to Plus
Possible Symptoms
Airbag Warning Light ON
Possible Causes
Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179) faulty
Airbag Control Module (J234) faulty
Possible Solutions
Check Wiring/Connections between Airbag Control Module (J234) and Crash Sensor Side Airbag; Driver Side (G179)
Replace Crash Sensor Side Airbag; Driver Side (G179)
Replace Airbag Control Module (J234)
01221 - Crash Sensor Side Airbag; Driver Side (G179): No or Incorrect Basic Setting / Adaptation
Possible Symptoms
Possible Causes
Wrong Crash Sensor Side Airbag; Driver Side (G179) installed
Possible Solutions
Install correct Crash Sensor Side Airbag; Driver Side (G179)
Special Notes
The Crash Sensors can be checked by using the control module identification and the measuring blocks.
Address 15: Airbags
   Controller: 1T0 909 605
   Component: 05 AIRBAG VW62 0506 2112
   Coding: 0012341
The 0506 in this example stands for the required Crash Sensor ID, the first 2 digits (05) apply for the front crash sensors, while the second 2 digits (06) apply for the rear crash sensors. The ID of the currently installed Crash Sensors can be determined by checking Measuring Value Block (MVB) 009.
01221 - Crash Sensor Side Airbag; Driver Side (G179): Implausible Signal
Possible Symptoms
Possible Causes
Wrong/Incompatible Crash Sensor Side Airbag; Driver Side (G179) installed
Possible Solutions
Check Crash Sensor Side Airbag; Driver Side (G179) Part Number
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Airbag fault
« Reply #25 on: January 06, 2011, 12:56:50 pm »
Offline nads1_uk
Re: Airbag fault
« Reply #26 on: January 06, 2011, 01:08:43 pm »
Possible Symptoms
Possible Causes
Possible Solutions
Possible Symptoms
Possible Causes
Possible Solutions
Special Notes
Address 15: Airbags
   Coding: 0012341
Possible Symptoms
Possible Causes
Possible Solutions
Cheers Carl you're a legend!  :notworthy:
My car is out of warranty -   :sad1:
What would you suggest let the dealers have a look and see what they come back with?
Do you have any idea what the worst case costs would be?
Is there anything I can check that might be simple to do?
Andy
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Airbag fault
« Reply #27 on: January 06, 2011, 01:37:15 pm »
It depends how mech & tech minded you are.
If your happy with the location of everything and removal of seats/trim then yes by all means check the wiring in the areas highlighted above.
If not then just take it to a dealer. you may get charged a diagnosis fee, prob around 1/2 hour labour, this is what my dealer would usually charge but i have VCDS. That would just be for them to tell you what the problem is without doing anything about it.
But as i said the dealer will be able to follow the guided fault finding they have and from that they would be able to give you an idea of cost.
Worst case scenario i would say £600. Thats if you needed all new wiring, Igniters and labour on top. I would be surprised if it was both wiring and hardware.
Offline nads1_uk
Re: Airbag fault
« Reply #28 on: January 06, 2011, 08:56:34 pm »
Hi Carl
  Cheers for all the advice I'll get it booked into the dealers and let you know how I get on.
Andy
