Author Topic: Another Cruise control retrofit question....  (Read 5914 times)
Offline Callumrobin
« on: December 28, 2010, 05:47:47 pm »
Hey guys,
I currently have an 04' Plate Mk5 Golf 1.9 TDI, it is the basic model so doesn't have any multifunction computers at all.
I've read all the different fitting guides on various different search engines etc and feel confident to fit it and run the required wire for the control module.
My question is; Will I need to change the control module on my car due to it being the basic model? I have the VW kit already with the stalk and wire etc, but wondered if I will need to change any other modules to make it work?
I already have a vag-com and I'm pretty happy with the coding side of things, but wondered if anyone had fitted a kit into this type of model of car?
VRSTU previously fitted a kit on Fabia VRS years ago, so thought he may also be able to shed some light?
Thank you in advance for any help.
Callum :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Another Cruise control retrofit question....
« Reply #1 on: December 28, 2010, 06:43:27 pm »
Hi
You will need to change the steering control unit
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
best you look here to see what one you have
(I have a midline type 2 control unit and slip ring for sale)
You will need to remove the wipers to get to the E-Box
coding is easy, remember to code the Engine
Cluster and Key coding
Location Great Yarmouth
Offline Callumrobin
« Reply #2 on: December 28, 2010, 07:31:09 pm »
Cheers for the help, how much you looking for the control unit? Would I need the slip ring as I don't have the MFSW?
Thanks again for the advice
Callum
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: December 28, 2010, 07:41:32 pm »
Hi
the part number is 1K0 953 549 F and is a type 2 midline (trip computer and Cruise)
Your car is a 2004 car and most will have type one controllers which will have type one slip ring
I'm looking for £25 delivered
thanks
Ed
Offline Callumrobin
« Reply #4 on: December 28, 2010, 11:15:05 pm »
Sounds good mate, I'll check the controller tomorrow & let you know.
Where abouts are you based?
Callum
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: December 29, 2010, 10:07:11 am »
Callum
Hi
I'm in Great Yarmouth, Norfolk
Offline Norbreck21a
« Reply #6 on: December 29, 2010, 11:28:31 am »
Eddie,
Why did I always think you were based across the other side if the Irish sea?
Are you just over here for Xmas or permanently?
Andrew
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: December 29, 2010, 03:15:59 pm »
Hi Andrew
You probably looked at my user name and thought that the NL bit was for Northern Ireland NI
The NL is for The Netherlands (Holland) as I'm half Dutch. I would like to go back and live in Holland but property is so expensive
Ed
Offline Callumrobin
« Reply #8 on: December 29, 2010, 07:44:54 pm »
[/quote]
Hi
[/quote]
Didn't get a chance to check today, hopefully check in the morning...
Ahh Norfolk is quite a trek! Post it is then!!
Callum
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: December 30, 2010, 05:38:47 pm »
Looks like you have a way forward Callum, keep us posted with progress.
Stu...
Offline Callumrobin
« Reply #10 on: February 06, 2011, 06:09:09 pm »
Finally got round to fitting this today, took a bit  longer than expected with certain parts being a pain!!
Firstly the one windscreen wiper just really didn't want to come off, then the wiper motor was being a pain, then the wire for the top blue plug just really didn't want to go in!!! :fighting: But all was fine in the end, apart from a couple of issues if anyone can help?
I changed the controller and steering wheel ring, and managed to code the cruise control fine by:
Selecting 01 Engine
Login 11
Entered 11463 to activate (and this was fine and accepted)
My issues are that the cruise is still not working, and it's now coming up with a steering wheel and ESP fault?
Are there other parts I need to code in? Does the steering wheel ring need to be coded? I'm struggling a bit as my VAGCOM is the older version and I can only get into the Engine section of the ECU, I guess I might need a canbus connector to access the other areas?
Any help much appreciated.
Callum
Offline Callumrobin
« Reply #11 on: February 06, 2011, 06:23:45 pm »
I see I need to change the coding on the steering control module, but guess I need a canbus vagcom to do this?
Anyone in the Gloucestershire area with one?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #12 on: February 06, 2011, 06:26:50 pm »
Yes you need to code 16 the Steering controller.  I assume yours is a TDi if you used 11463.  And yes you need at least a MicroCAN but a Hex+CAN is the better cable.  Try the registered users post in the VCDS area.
The other faults will likely because you'll need to carry out basic setting adaptations on the Steering and ABS controllers.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
Stu...
Offline Callumrobin
« Reply #14 on: February 06, 2011, 06:52:52 pm »
Massive thanks for this matey, least I know what to do now!
Just need to find someone in the area with a cable!!
Are you still based down in Portsmouth? Might have to pop down there otherwise!!
Callum
